Question about Denon Audio Players & Recorders
Can I connect my record player to my Denon UD-M30 receiver?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
If the amplifer doesn't have a PHONO input, then you will most likely need an external phono preamplifer. Most vintage turntables and cartridges have too low a signal level to connect to todays modern amplifers that don't have phono inputs. An external preamplifier will also have the correct RIAA response curve for records. Without this curve, the recordings will sound awful.
Posted on Apr 02, 2015
  • 739 Answers
That would depend on if both units have input/output jacks on them. typically yes, though you may need some plug end adapters to accomplish it
Can I connect my record-Player [Pioneer] to my Denon UD-M30 Receiver?
that would depend on if both units have input/output jacks on them. typically yes, though you may need some plug end adapters to accomplish it
Apr 02, 2015 | Denon Audio Players & Recorders
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
DENON UD-M30 CD Player is displaying the word PROTECT and will not function. Any ideas how to fix this problem? Many thanks.
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Mar 10, 2011 | Denon CDR-M30 CD Recorder
I need to find the instruction manual for a Denon UD-M30 CD Tuner. Can you help please?
You can get the manual on the link below. Just click on where it says it is free.
http://safemanuals.com/user-guide-instructions-owner-manual/DENON/UD-M30-_E
Good Luck please rate 4 thumbs and please leave a testimonial
Oct 05, 2010 | Audio Players & Recorders
Denon CD receiver - Auxiliary function not working
this is front headfones nearby cd player control knob
Nov 22, 2009 | Audio Players & Recorders
CD JUMPING
Try looking into the lens (power off) with a magnifying glass. If you see any damage you will need to replace the lazer/lens section as the lens will never be able to read the disc.
If it's clear it's more likely to be an electronic fault.
Aug 26, 2009 | Denon CDR-M30 CD Recorder
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
No Aux on a UD-M30
We had the same problem, found that if you plug your device into "line 2 in" on the back and select tape it worked for our ipod. We had to turn the volume right up on the ipod to hear it though
Nov 12, 2008 | Denon CDR-M30 CD Recorder
Disc reading
How confident are you at opening it up? And where are you? If it can get table of contents info it could be gummed up grease on the laser sled.
Jun 15, 2008 | Denon CDR-M30 CD Recorder
Denon ud-m30
Yes it maybe a laser,if the repair cost still reasonable,why not.
Dec 14, 2006 | Denon CDR-M30 CD Recorder
161 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
