Question about Sharp Televison & Video
My Sharp TV started rolling and the color was off. I turned it off for about hour and when I turned it back on it was good for about two hours, then it happened again. what can I do?
I was watching and the TV started rolling and the color was off. I turned it off for about hour and when I turned it back on it was good for about two hours, then it happened again. Now it does it all the time. What's wrong?
  • Wayne Blankenship
    Wayne Blankenship Apr 02, 2015
    Here's the model #Lc-70le650u and thanks for your help.
  • 700 Answers
Unfortunately system suggest that either - high voltage regulator capacitor is gone or thermal protection on power board is on way out - need technician to determine exact cause and repair.
as you did not supply which model - unfortunately only general advice can be given...
Posted on Apr 02, 2015
  • Wayne Blankenship
    Here is the lc-70le650u Thank you for your help.
  • bzet1820 Apr 03, 2015
    i am suspecting that this tv is still under warranty - just visit this site and check:http://www.sharpusa.com/ForHome/HomeEnte... follow info on the site, you will need to register. sharp will pick up the unit from your home and deliver it back for free, sometime they even provide on spot replacement. hope this will solve your problem...
    Top Expert:
  • Sharp Master
  • 74,118 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
Vertical colored bars upon turning on TV when tv is on for an hour picture finally comes on
Ribon connector for that area on the panel needs to be unpl;uged and clean and reserted back into place and thyat should fixyour problem.
Jul 08, 2011 | Sharp LC-32AV22U 32 in. LCD TV
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
Lost the red color from my Sharp LCD TV
Reboot ur HDTV box buy unplug and replug is an hour later,see if get the color back.If not,than ur Sharp tv Main Tuner signal board is dead that the problems,must replaced the Tuner signal board to solved this problems.
Mar 05, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Help this guys! with an hour my tv is turn off the power in ....
If you learned how to spell and punctuate sentences it would ber easier to help you.
Mar 30, 2009 | Televison & Video
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Jul 29, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Rolling Picture
Mebe the tv tuner no good.
Ben.
Jan 12, 2008 | RCA 27V530T 27" TV
Televison & Video Logo
230 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
