Question about Staples One-Touch Heavy-Duty 3-Hole Punch, 30-Sheet Capacity
How do you empty the contents? - Staples One-Touch Heavy-Duty 3-Hole Punch, 30-Sheet Capacity
    Top Expert:
  • Staples Master
  • 44,448 Answers
Remove the tray underside
Posted on Apr 02, 2015
How do i drain the base pan of a kelvinator kd12mm1
Kelvinator believes you should be able to remove it and dump contents into a drain. In real life you may have to sponge up contents, then remove and clean the empty pan.
Jul 03, 2017 | Kelvinator Refrigerators
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
My Lg Xpression will not delete 1 message and keeps saying empty content when touched on
Its an phone memory file system crash.. No need to worry. backup all contents except messages. There will be a option to restore factory settings in your phone. Reset it.. The message will be erased automatically
Dec 20, 2012 | Cell Phones
E04...how to setle it
That error means that an ink cartridge is empty. To cancel printing, press the Stop/Reset button. To continue printing, press the OK button. After the printing finishes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause machine malfunction.
You can read more about the error codes on Canon website: http://support-au.canon.com.au/contents/AU/EN/8000137001.html
Dec 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
I buy new kingston pen drive I copied some folder (collection of xls files ,and setup) Now i unplug it and agian check it then it show only folder but with empty content means all folder become...
Its due to corruptness of your drive.Your content not properly copied in pendrive. Dont worry just format your pendrive thoroughly not quick. Then you may copy your content properly. your problem will be solved...okay
Aug 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Shows more stored on hard drive than is there. Keeps saying hard drive space running out.
Empty the "Recycle Bin"? Files are not really gone until you empty the contents of the "Recycle Bin". They still take up drive space.
Oct 08, 2009 | Gateway M275 Tablet PC
1998 Ford taurus what does the push for % alchol mean????
it is telling you the alcohol content of your fuel. Check your owner manual.
Flexible Fuel Vehicles (FFV) also include:
  • digital miles to empty indicator.
  • alcohol percentage read button.
Mar 05, 2009 | 1999 Pontiac Grand Am GT
Cannot access memory card
what to do you can copy all of the contents from your card to the pc...then reformat the card and add back the content to the card and put it in the phone.
If that does not help then try the card in another phone and if it reads then your phone needs to be checked.
Nov 02, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Staples One-Touch Heavy-Duty 3-Hole Punch, 30-Sheet Capacity Logo
464 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
