Question about Stoves Ovens
Is there an internal fuse in my Stoves Teba Electric cooker?
    Top Expert:
  • Stoves Master
  • 52,126 Answers
Google the mfg's website and ask tech support
Posted on Apr 02, 2015
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
Moved house no manual to stoves cooker model 4444451 72oef
You will need to post an email address and then i will send you a pdf copy of the handbook.
Sep 02, 2011 | Stoves 720EF Electric Double Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Can I download a Manual for a Stoves 61EDO cooker. I am specifically wanting to know how to use the timer. Thanks
I have posted how to use the timer on the 720 on other solutions. Try that to see if it works.
Mar 23, 2011 | Stoves 720EF Electric Double Oven
Need instruction manual for stoves heritage 720EF cooker
Supply an email address and I will validate it on my BT Digital Vault to give you access to take a copy of the Handbook.
Nov 03, 2009 | Stoves 720EF Electric Double Oven
I have just got a new stoves cooker and i need the manual for it, the model number has worn away a bit but from what i can see this is the model number 039850512
If you contact STOVES with that number, they should be able to help you. If you want a copy of my 720EF manual, supply an email address and you can gave a copy.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
97 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
