Question about Bosch AQUATAK 110 Pressure Washer
The end of the lance won't spin How can I fix it?
No water pressure when wand is squeezed
check the nozzle isnt blocked easiest way to do this is remove pipe from lance handle and see if it fires water at pressure when lance isnt attached if it does fire water at pressure then your spray nozzle is blocked or turned off at the nozzle the nozzle can sometimes spin to far round and close
Apr 21, 2015 | Garden
Can I buy a replacement lance
google make/model/parts many home improvement stores carry replacement lances .
Mar 25, 2015 | Garden
Dvd player won t read disc
In most cases it is either the motor which rotates the disc goes slow or the optical unit or lance goes bad. Apart from this there may be dust deposition on the lance.In first two case you need the help of a technician. Dust cleaning can be done by lance cleaning disc. Good luck.
Jan 18, 2014 | Philips Televison & Video
I can't get my device to "set" for drawing blood
Not 100% sure as I use a different device but after pulling back to set, try placing correct end onto sikn and press the other end to make it work, alternately there may be a button on the side that changes colour that must be pressed. If these do not work try calling the following (888) 469 3579, which should put you in contact with Advocate. Hope this helps
Mar 29, 2013 | Advocate Lancing Device
My 2002 Mitsubishi lance won't start i put a valve
I answered this on another post of yours I believe.
Nov 11, 2012 | Cars & Trucks
My playstation 1 won't play any games. It will start up with the disc spinning but then the disc stops spinning and i end up on the memory card screen.
DEAR FRIEND CHECK YOUR PS LANCE EYE AND CLEAN I HOPE READ PLY STATION LOGO THAN NOT PLAY , CHECK YOUR PCB BORD RBI CHANGE THAN REMOVE YOUR PROBLEM I HOPE SOLVE YOUR PROBLEM TACK CARE
Aug 21, 2011 | Video Game Consoles & Games
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
Dear sir/madam I bought a kArcher model K3.97
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Nov 08, 2009 | Karcher K2.26 Electric Power Washer
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
Bosch AQUATAK 110 Pressure Washer Logo
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
