The end of the lance won't spin - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
Posted on Apr 20, 2015
No water pressure when wand is squeezed
check the nozzle isnt blocked easiest way to do this is remove pipe from lance handle and see if it fires water at pressure when lance isnt attached if it does fire water at pressure then your spray nozzle is blocked or turned off at the nozzle the nozzle can sometimes spin to far round and close
Apr 21, 2015 | Garden
Can I buy a replacement lance
google make/model/parts many home improvement stores carry replacement lances .
Mar 25, 2015 | Garden
Dvd player won t read disc
In most cases it is either the motor which rotates the disc goes slow or the optical unit or lance goes bad. Apart from this there may be dust deposition on the lance.In first two case you need the help of a technician. Dust cleaning can be done by lance cleaning disc. Good luck.
Jan 18, 2014 | Philips Televison & Video
I can't get my device to "set" for drawing blood
Not 100% sure as I use a different device but after pulling back to set, try placing correct end onto sikn and press the other end to make it work, alternately there may be a button on the side that changes colour that must be pressed. If these do not work try calling the following (888) 469 3579, which should put you in contact with Advocate. Hope this helps
Mar 29, 2013 | Advocate Lancing Device
My 2002 Mitsubishi lance won't start i put a valve
I answered this on another post of yours I believe.
Nov 11, 2012 | Cars & Trucks
My playstation 1 won't play any games. It will start up with the disc spinning but then the disc stops spinning and i end up on the memory card screen.
DEAR FRIEND CHECK YOUR PS LANCE EYE AND CLEAN I HOPE READ PLY STATION LOGO THAN NOT PLAY , CHECK YOUR PCB BORD RBI CHANGE THAN REMOVE YOUR PROBLEM I HOPE SOLVE YOUR PROBLEM TACK CARE
Aug 21, 2011 | Video Game Consoles & Games
When i connect my vario pressure lance to the gun it leaks like a sieve thus reduced pressure but when i fit my other accessories its ok???
It sounds like you have the vario lance set to low pressure or "mix". If you twist the end of the lance you can increase and decrease the pressure. The setting you have it on is for when you are applying detergent through the pressure washer hence why it is a wider low pressure jet.
please remember to thumbs up, thanks.
Mar 19, 2011 | Karcher Garden
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
Washing Machines Logo
Top Washing Machines Experts
