What is E7 - Heating & Cooling
    Top Expert:
  • 44,327 Answers
Without make and model how can we tell since all mfg's use different codes .
Posted on Apr 02, 2015
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
I have forgotten my password for nokia e7 how can i hard reset
Follow the steps to hard reset nokia e7:
Before doing the master reset and format Nokia E7, ensure that you have backed up important data
1. The Nokia E7 battery should be charged fully
2. Turn Off Nokia E7
3. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
4. The Nokia E7 will reset
OR
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
GuruAid.com
Jan 04, 2015 | Nokia E71 Smartphone
User manual
Moscon E7 from SAMSUNG is same as
Yaskawa E7
You can find it at https://www.yaskawa.com/pycprd/products/hvac-drives/drives/e7-drive
Jun 17, 2014 | Electric Electronics - Others
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
HELO
E7-00? = At initialization the white level correction cannot be completed.
You have to clean the white reference plate. Lift the Doc-Feeder, identify the white strip and clean any pen-marks or dirt!
BUT the rest of the code would help!!
  • E7 codes have sub-codes (read by pressing the ‘Print’ button)
  • E7-03 = "Laser Output Error"
  • E7-04/E7-05/E7-12 all refer to problems with the digital reading & laser output
  • E7-15 = Copy Lamp Output problem (doesn’t see the Exposure Lamp light)
  • Nov 19, 2007 | Sharp AR-5316 Advanced Digital Imager...
    Heating & Cooling Logo
    27 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
