How to fix over heating thermostat, not following auto settings?
I have set the thermostat at my house at set on auto at 21 degree. However since this morning the temperature increases to 26 degrees and beyond and not coming down. The house is quiet warmed up, so please advise on issue and troubleshooting
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Sounds like there is a problem with the a/c and not necessarily with the thermostat. Is the outdoor unit running and discharging warm air? If its running and the air is cool, either the compressor itself isn't running or there is a refrigerant issue.
Verify what the system is doing, then consider contacting a reputable service organization in your area.
Posted on Apr 18, 2015
5 Suggested Answers
  • 5129 Answers
SOURCE: need to find out why my honeywell rht4650d thermostat is reading "in recovery"
The problem is likely with the cooling system, not the thermostat itself. Either the message from the thermostat is not being received by the AC unit, the solenoid isn't turning on the unit or it can't cool properly.
First check that none of the wires to the thermostat are loose or broken. You'll have to take the face plate off to check. The conductors are very small wires and can break easily. Depending on the unit,there are 4-5 wires usually for a HVAC system. If a wire is loose, reconnect it (push it in or screw it down gently). If a wire is broken, strip (for screw terminals) a new section and reconnect it. Check for ice build up on the condenser coils. (That is often a sign of a refrigerant leak. You'll need a professional to fix it and recharge the unit.)
Do you hear the fan running? If you do, then the condenser is a likely culprit. If the fan isn't running, then the control board for the system may be bad. You may want a professional to check the system. If you tell them the make and model, the technician can bring the parts if it is a problem with the control board.
I hope this helps.
(We had the broken wires to our thermostat in the winter. A few years ago, a nearby lightning strike had the AC off in the summer due to the control board damage. The house reached 90 degrees while we waited for the repair.)
Posted on May 31, 2013
  • 3368 Answers
SOURCE: I changed my wireless setup and router, now the thermostat says connection lost, I followed the instructions to reset but the WiFi set up doesn't come up How do I reset the Wifi I have the RH
Be sue the router is on and is not blocking it.
Posted on Dec 18, 2014
  • 173 Answers
SOURCE: I have a Honeywell programmable thermostat and I
I would say that the problem is in the furnace, not the thermostat. The Thermocouple or other temp sensor needs replacing, the sensor that tells the furnace that it is heating. It just keeps turning off and trying again in 3 minutes cycles.
Posted on Jan 01, 2015
  • 90 Answers
SOURCE: I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80.
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Posted on Feb 09, 2015
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
Jun 21, 2017 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Wont allow me to set thermostat below 73 degrees?
You never said what type and model of thermostat you have....... If you have a digital stat You may have to lower the HEAT setting below 67 degrees if you want to set the AC to 70 degrees. If the thermostat has an Auto feature then it has to have a 3 degree differences between heating and cooling. On the newer models it does it automatically if you lower the Cooling setting it will lower the heating setting......It this doesn't help repost with more information so I can help you better....
Mar 28, 2011 | Heating & Cooling
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Heating & Cooling Logo
344 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
