Possibly a fuel supply issue. Will require a fuel pressure tester. Could be in tank pump or a bad fuel pump relay. In a quiet environment, turn key on (not start position ) and listen if you can hear the guel pump run for 1 or 2 seconds.
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
You normally have to while the car is running transmition in neutral push the brake pedal, put the emergancy brake on, release the foot brake, press the remote start button on the remote, take keys out of ignition switch, car should stay running, get out, press the lock button on remote starter remote, car should shut off, and now is set
Lock all the doors unlock the doors with the key because the security system thinks its being stolen and it shuts off the injectors
Try another key the chip in yours may be defective.
