Can i have a full view of the amplifier circuit board?
  • Audio Player... Master
  • 5,126 Answers
To do that the fixya experts will need to know the make and model number of the amp in question.
Posted on Apr 18, 2015
Can i have a full view of a MTX Thunder 81000D amplifier two resistor got burn beyond recognizance and i need to replace them
Not sure about getting a better view but I suspect that you have more problems than just replacing the resistors. Like what caused the resistors to burn?
Apr 30, 2015 | MTX Car Audio & Video
Where can i buy circuit boards for my pheonixgold 600.2 amp,so i can rebuild it myself?
Check directly with Phoenix Gold regarding availability of the circuit boards.
Jul 04, 2014 | Phoenix Gold Titanium 600.2 Car Audio...
Screen becomes full of lines and picture dissappear but sound noot affected
These lines are called vertical retrace lines. The fault is related to its video amplifier section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
How to fix cracked PCI board in a amplifier
If the PC board is a single layer board then you can remove the coating on the printed circuits either side on the crack and then solder a small piece of wire on the printed circuit tracks. This will bridge the printed circuits across the cracks.
If the PC board is a multi-layer board then it is impossible to repair and the PC board needs to be replaces if you can get one. It maybe cheaper to get a new amplifier.
Feb 14, 2013 | Motorola Mobility KRZR K1 Motherboard Flex...
Pre-amp circuit board. i have one transistor bad. can it be replaced or do i have to replace the full circuit board?
transistor is a lot cheaper than the whole preamp board .
But .....
If availability or replacement is the problem could be.
unless you know how to find the replacement for what it is.
Sep 26, 2012 | Peavey Audio Players & Recorders
View lifestyle keeps powering off
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 22, 2011 | Bose Audio Players & Recorders
My circuit boards are damage.how can i get new circuit boards for my ep2500.
I would contact the maker of the amp. They should know if the are still made or where to get them.
Feb 04, 2011 | Behringer EUROPOWER EP2500 Amplifier
Plz send me ssb-120 pa amplifier circuit digram
Hi i think this is what you are looking for, takes a while to load but checked and its the full instruction manual.
http://ahujaradios.com/Literature/SSB-120_OM.pdf
please rate :)
Feb 05, 2010 | Alpine Audio Players & Recorders
TECHNICS SUPER BASS, DOUBLE BASS AND TRIPLE AMPLIFIER
Have you checked all circuit boards for good solder connections.
Also if the boards had been wet from anything, you might clean the boards and resolder all connections specially in the power supply and audio section.
Let me know.
Jan 26, 2009 | Technics SUV500 2-Channel Amplifier
195 people viewed this question
 Grubhead
Grubhead
