Question about Refrigerators
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
  • Refrigerators Master
  • 5,323 Answers
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Posted on Apr 28, 2015
jgwhomeequip
  • 1902 Answers
SOURCE: loud noise
Check the relay on the side of the compressor. Has a metal clip holding it to the compressor. Check with a volt meter and also check the compressor for voltage. no voltage or low at the compressor replace the relay. You can also take the relay off and shake it. If it makes a rattling sound replace it
Posted on Feb 14, 2009
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
SOURCE: Kenmore Elite Refrigerator 59676264700 loud clicking noises
check for bad relay
Posted on Jul 29, 2009
  • 1218 Answers
SOURCE: I have a kenmore side by side refrigerator
Good day,
The most common reason for noise is the fan motor in the freezer compartment.
Remove the screws from the rear panel in the freezer compartment and inspect the fan motor. Replacing it is a fairly easy nuts and bolts procedure. The motor should be available at most appliance parts houses.
kenmore is a trade name for Sears appliances. It was made by either Whirlpool or Frigidaire.
Posted on Sep 06, 2010
  • 129 Answers
SOURCE: refrig making noiise
They are telling it is normal because they dont want to replace it. When in all honesty it isnt. Behind the inside pannel is a protective layer of insulation with a thin layer of metal. The insulation is either not covering the entire plactic sheild. Causeing the metal to contract. It will also make it run more because it warms up faster than needed. Thats where you hear the loud noise comming from. I would demand they take it back to the store and replace it with a new one or call the better buisness beu. Hope this helped.
Posted on Nov 24, 2012
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have an old zenith sentry tv, and up to know has never had any problems. Afew days ago it started making a very loud noise as soon as I turned it on. It sounds like it's coming from the right
someone needs to open it but it sounds like a part arcing which was not uncommon in those sets====you would have to decide if you want to attempt to have it repaired----some shops will not repair a set that old and unless you really want it done---I would replace it.
Mar 17, 2012 | Zenith Televison & Video
02 4x4 olds bravada makes loud clanging noise when turning wheel
Have your CV boots and half shafts checked. If these are cracked, they will dry out and cause a lot of noise when turning. Also check your swaybar links, these cause a lot of noise also, but not only while turning.
Feb 10, 2012 | 2004 Oldsmobile Bravada
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
After 10 sec. After start up the tv starts to make a large growling sound for about 5 secs. Then repeats every 15 sec. Sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
there's 3 fans. 1 by the video board. 1 in the middle of the set infront of the heatsink and 1 behind the lamp. make sure all 3 fans are running and put your ears by them to check. if all of them are running the sound might be coming from your colorwheel. If it sounds like a loud whinning/humming or buzzing noise then more then likely its your colorwheel. Let me know what you find and please rate me. Thanks
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
42 " plasma cutting out and making a loud clicking noise
I would have to say take it back. Make them replace it before you get stuck with it. Customer satisfaction is on your side. 90 day warranty.
Jan 18, 2009 | Samsung HP-S4253 Television
Shut down problem
Try getting in through Safe Mode by tapping the F8 key while the computer is booting.
If you can get in.
Right click on My Computer, select Properties, click Advanced, click on Settings for Startup and Recovery. Make sure there is NOT a check in the Automatically Restart box.
Apr 18, 2008 | Acer Aspire L100 PC Desktop
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
