Question about Dryers
My triton t90z makes a loud switch off noise 15 secs after its turned off. Its the thermal switch should I have it fixed?
  • Dryers Master
  • 5,323 Answers
WHEN THE THERMAL SWITCH IS BAD U WILL GET NOTHING? SO I SUSPECT ELSEWHERE
Posted on Apr 03, 2015
  • 6 more comments
  • Emma Keane
    Emma Keane Apr 03, 2015
    Ok well thankyou for that
  • Jorge Rendon
    Jorge Rendon Apr 03, 2015
    this is an electric or gas?
  • Jorge Rendon
    what does the noise sound like?
  • Emma Keane
    Emma Keane Apr 04, 2015
    Its an electric shower. It makes a click noise as if a switch has just clicked
  • Jorge Rendon
    Jorge Rendon Apr 04, 2015
    Electric shower? that sounds scary the combination of water and electricity? In any case if its an electrical system switch,, it may have a form of relay or capacitor which is going bad hence the clicking. you might try to google it putting " electric shower clicks after turning off?" Good luck sorry cant help much
  • Emma Keane
    I have a triton engineer due to call will post what he says.
  • Jorge Rendon
    ok waiting
  • Emma Keane
    Emma Keane Apr 11, 2015
    Triton guy says its the new set up of these showers. Its a thermal cut off switch as such.
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
My triton t90z has no water coming through
If you hear the pump pumping as normal then it is most likely the solenoid. Try phoning www.dublinshowerrepair.com
0872885385 they'll give free advice and stock Triton and Mira parts
Jan 12, 2013 | Home
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dryer won't heat
i only ask this because you mentioned the loud noise are you almost out of propane, is it a pop sound or ?
Jun 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Dryers Logo
88 people viewed this question
Top Dryers Experts
