Question about Home
Anyone know anything about noisy t90z showers?
My triton t90z has no water coming through
If you hear the pump pumping as normal then it is most likely the solenoid. Try phoning www.dublinshowerrepair.com
0872885385 they'll give free advice and stock Triton and Mira parts
Jan 12, 2013 | Home
Noisy shower/bath mixer unit
You have low pressure connect cold supply to mains
Sep 19, 2012 | Home
I installed new moen shower valve i tested it before i put the walls up 6 months later finaly got done with bath room no water comes out now
During construction did you perhaps close off a shut off valve within the water line and not reopen it? If not do you hear anything at all when you turn the shower faucet on? Let me know.
Jul 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Im installing a shower panel in my shower
You must have gfci protection since the power is going to the shower and you don't want anyone to get electrocuted. You can either use a gfci breaker or you can install a regular gfci outlet between the panel and the shower. The outlet will be a cheaper solution to the issue.
please mark this answer as a fixya!
Mar 08, 2009 | Dreamline SHCM-2358-00 Aluminum Five...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
55 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
