Question about Murray Garden
Fuel pump Not getting fuel to carburetor - Murray Garden
  • Kprime
    Kprime Apr 06, 2015
    Hi chintight ford, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
Fuel pump may have trash inside of it, be gentle with ur disasemblly, then hook an air hose to the fuel lines and blow them out
Posted on Apr 06, 2015
The fuel system on a X speed 50 R i'm not getting fuel to carburetor it's past the fuel filter but not to the carburetor
Hi, Sam always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.49ccscoot.com/manuals/Yamaha_BWS_Zuma_50_2T_Service_Manual.pdf
50CC 2 STROKE PARTS
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Nov 23, 2016 | Motorcycles
Why is hardly any fuel is getting to my carburetor the fuel pump is working
If the fuel pump is working and there is no fuel to carburetor , look for two things, blocked fuel filter or line, or stuck needle and seat.
Oct 03, 2016 | Cars & Trucks
Not getting gas to carb
It could be. Since you have a carburetor, you must have a mechanical fuel pump on the engine? Only some imports with carburetors had an electrical pump.
If your filter is in the line just before the carburetor, take the line off at the filter, then crank the engine over to see if the pump is working. Mechanical fuel pumps will pump gas when the engine is cranking or running. Use a jar or can to catch the gas. If pump is working, fuel will come out in small spurts. It's not under high pressure- carbs don't need high pressure. If no gas comes out of the line, you probably need a new fuel pump. If the pump is working, it could be the filter, but could also be the needle valve and seat at the carb's fuel inlet. Sometimes they get stuck closed and won't let gas into the carburetor.
Aug 01, 2015 | Cars & Trucks
How to tell if 1995 ra1 honda odyssey fuel pump working or not??
It sounds like there might be an air lock between the fuel pump and the carburetor. Disconnect the fuel line from the fuel pump at the carburetor. Get a coffee can or another container turn the fuel pump on or try and start the car. the fuel pump will pump fuel through the fuel line to fill it with fuel and push the air out of the line. When you get a steady stream of fuel , reconnect the fuel line to the carburetor, the car should start.
May 28, 2014 | 1999 Honda Odyssey
Yamaha Grand Axis 100 not getting fuel to carburetor
Hi, Anonymous always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
Two Stroke Motorcycle Troubleshooting Guide Cyclepedia
http://turbobit.net/yvz91pdf01mm.html Service manual rar file
https://japan.webike.net/YAMAHA/GRAND+AXIS+100/784/oem_parts
YAMAHA BWS YW100E Owner Manual
Jul 16, 2017 | Yamaha Motorcycles
Carburetor does not let fuel to engine
check the fuel lines and filters for blockages
Remove and check all fuel filters located in the fuel line and in the carburetor.
Replace any and all filters that can not be confirmed good or have not been changed recently.
Inspect the fuel lines for leaks or kinks that might interfere with fuel flow.
Tap the top of the carburetor lightly to free a stuck needle valve or float that may be shutting off fuel to the carburetor float bowl.
Check the fuse marked fuel pump in the fuse box for any electric fuel pump equipped vehicles.
Connect a fuel pressure gauge to the Shrader valve if the vehicle has an electric fuel pump. Turn on the key and monitor the fuel pressure, it should be around 60-psi.
If equipped with a mechanical fuel pump, remove the fuel line to the carburetor and connect a fuel gauge to the fuel pump.
This should yield a low pressure, under 20-psi when the engine is cranked over.
Check the mechanical fuel pump by placing a fuel line into a gas can and attach the other end to the intake of the fuel pump.
Crank the engine and check for fuel at the carburetor.
The engine may start with fuel from a remote source such as a fuel can.
If the pump draws fuel from the can and not the tank the tank screen must be inspected and or replaced.
This would require removing the gas tank.
hope this helps
Oct 11, 2012 | Motorcycles
Yamaha Cygnus has petrol problem Has spark fuel not getting to carburetor
Hi, Aaronslocks always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Fuel not getting in carb
https://traxxas.com/forums/showthread.php?366591-Fuel-not-getting-to-carb
Yamaha XC125 Service Manual
OEM parts for Yamaha
YAMAHA CYGNUS XC125 Owner Manual
Mar 16, 2012 | 2006 Yamaha CygnusX
25cc featherlite weedeater not getting fuel into bulb when you pump it, nor does it seem to be getting any fuel at all. pour a little gas in carb and it will start and run til gas is gone. What's up with...
Check the condition of the fuel filter/fuel line inside the fuel tank. It could be clogged. The line that feeds the carburetor is connected to a fuel filter inside the fuel tank. Also, the carburetor could be clogged with debris, especially if the fuel line has come off of the filter inside the tank. They get brittle and break, sometimes causing your problem. There is a fine mesh screen inside the fuel pump side of the carburetor (the side without the vent hole) that sometimes needs to be cleaned off to allow proper fuel flow thru it. Remove the carb and remove the fuel pump cover and check the condition of the filter screen after checking condition of fuel lines and fuel tank filter.
The bulb will sometimes not "pull" and "push" the fuel right if the check valves inside the carburetor are malfunctioning, stuck or dirty. Start at the fuel tank and work your way to the carburetor. The fuel lines should be soft and pliable. Replace them if not. You should be able to blow air easily thru the fuel line that goes from the carburetor directly to the fuel tank. Check for all the above and post back if needed.
Oct 22, 2010 | Garden
U can see that the fuel pump is working but the car will not start. We have changed the fuel filter an there is gas getting to the carborator but very little. If u put gas directly into the carborator it...
There is a fuel pump relay but no pressure relay. If the pump is working then that eliminates the relay as the cause. I would disconect the fuel line to the carburetor and check the fuel pressure there. I believe it is supposed to be 12-14lbs. If it is less, the pump could be going bad.
Aug 25, 2010 | Cadillac Fleetwood Cars & Trucks
Just change the sparkplugs, overhauled the carburetor but still it is hard starting.My mechanic says i have to change my carburetor. is it right?
if your carburetor was overhauled correctly , no , you shouldn't have to change it. Are you sure your problem is fuel supply related? if so , hard starts are usually caused by the following : improper choke setting..a vacuum leak at the carburetor base or intake manifold or a hose ...a faulty accelerator pump ...low fuel pump pressure caused by a bad fuel pump or a clogged filter ....or too low of a gasoline float level in the carburetor.
Mar 03, 2010 | 1990 Toyota Corolla
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
