Question about Sansui Televison & Video
I have a 50"plasma TV, Sansui STY 02503 D. It's a dead set, when you switch it on you will hear a click sound of a relay & a glow of a red LED.
    Sergeant:
    Champion:
  • 267 Answers
The fact that the hair dryer allowed the set to come on tells me you have capacitors in the power supply that are leaky. I'd on the board as C1,C2 etc. The value of the part will be on plastic like caseing example 1000uf 25v. Look for a slightly domed top. That will be the bad ones. When replacing these make sure you put them in the same way as the ones that were in the set. They have a positive and negative lead. If you put it in reversed the new part will explode.
Posted on Apr 02, 2015
5 Suggested Answers
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
pizzaguy3274
  • 4 Answers
SOURCE: 42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Posted on Apr 12, 2008
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
I have 42" ,Sansui plasma tv .model number Sty 0342 . when i switch it on , the power led chages from red to blue, then suddenly goes red again .i've changed the power board but it keeps doing the same...
I have sansui television 42"model number STY0342, plasma 3D.when l turn it on sometimes it takes time to switch on after turning it on.it will change the standby light to blue.what might be the problem.
Dec 26, 2013 | Televison & Video
Tc-p42x3 panasonic problems
It sounds that there is some loose contact with any of the IC heatsinks inside the circuit board. Your TV need a through checkup. It is really a skilled work to do with Plasma displays, as they adopts the latest technology. Even an experienced service tech: too will feel a little bit difficult to reach the exact fault point. In my view, it will be better to contact any service technician in your TVs case. If you do wish to get some ideas about the working of Plasma displays, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 28, 2013 | Panasonic "Viera TC-P42X3 42"" Plasma TV -...
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
No display issue
Red means it is going into shutdown because something is wrong.
It will not come on again until problem is found and corrected.
What is model number and do you have a warranty?
Mar 12, 2012 | LG 50PS60 50 in. Plasma HDTV
I heard small pop then lost power while watching my lg 50pg20. No red or blue lights on the power switch. What could be wrong?
you are describing a power supply defect. IT may be as simple as the main fuse. I believe the one in this set is a 6.5 amp located on the ps board right by cord connection. IF after replacing the fuse opens a second time you will need to replace the power board.
p[lease leave feedback
Feb 20, 2011 | LG 50PG20 50 in. Plasma HDTV
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Nothing happens when i plug my TV in.
change the lamp cost around 200 dlls. and comes with 1000 hrs to 5000 hrs depends of the manufacturing brand.
May 18, 2008 | Samsung PPM50H2 50 in. Plasma Television
Televison & Video Logo
77 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
