Question about Hoover Washing Machines
Dryer is not now drying the clothes?
Hw5513
  • Hoover Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Posted on Apr 13, 2015
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer working to long to dry clothes
more than likely the belt needs to be replaced and the unit needs to be cleaned out (too much lint built up in the unit)
Apr 13, 2009 | Dryers
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Washing Machines Logo
49 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
