Question about AOC 919SW-1 LCD Monitor
The blue selection box for balance and contrast pops up without warning and will not go away, even when I push the button to do so on the monitor. Please advise.
    Novelist:
  • 242 Answers
Might be dust in the swites for the menu buttons.. try blowing out with air in a can..test the buttons to see if they snap when you push them and are not spongy feeling.
Posted on Apr 10, 2015
Blue mode box keeps popping up
Any unit, this monitor, a TV a DVD etc that has front push type buttons can have this issue.
Behind each "button" is a tiny micro switch--the outer button activates it and it is a MOMENTARY switch which means when the outer button is released it should stop functioning.
If you follow this what likely is bad is the micro switch under that specific button.
The switch will feel fine and seem ok but it is activating inside and what ever it controls will act.
Two ways to prove/disprove this.
Gain access to the individual switch (mode in your case) and unsolder it from the board they are usually mounted into--get the unit up and on and see if the problem persists or not.
Second way, with the buttons accessed take a good ohm meter and read across the two typical pins for each switch---there should be not be a bit of a reading unless the switch is manually activated---I have seen ones reading 4000 ohms and even more or less--even with switch out of the circuit.
Even that resistance is enough to activate the switch.
Prove for yourself that I am either right or wrong in your case.
Dec 19, 2012 | BenQ Q7t4 Fp71g 17" Inch Flat Panel Dvi...
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
I get a pop up with a RED CONTRAST screen every few minutes It sometimes goes away if I push the contrast button on my Dell monitor. but it will usually come right back. I have tried everything to stop...
You can try the monitor on another computer to verify it is the monitor and not the display card at fault.
I'm assuming this is an LCD monitor. If you are sure the monitor is the problem, then your monitor's display driver circuit is probably getting close to failing. When one of the three colors (red, green, blue) becomes intermittent, the screen takes on the hue of the working colors. In your case it sounds like the blue is starting to fail.
A repair technician may be able to replace the circuit.
Jul 22, 2010 | Dell Dimension 4700 PC Desktop
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
The brightness/contrast box keeps popping up without any buttons being pushed and sometimes scrolls through the options with nothing being pushed
There might be dirt underneath or close to the buttons.Try some compressed air to remove any dirt that might be there.Remember to unplug the monitor before you try to service it.
Good Luck
Oct 22, 2009 | Dell E153FP 15" LCD Monitor
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Contrast pop up
Is the OSD button stuck on the front of the monitor? Can you control the OSD menu with software or firmware? It may be the button interface/hardware.
Jan 03, 2009 | Computers & Internet
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
AOC 919SW-1  LCD Monitor Logo
140 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
