I have unscrewed all the pins at the bottom and taken the keyboard of but i can't for love nor money find where ram is on the Board i would like to upgrade my DDR3L SDRAM from 4 to 8GB can you help?
Acer TravelMate p256-M
    New Friend:
  • 22 Answers
Please consult your laptop's manual. I also hear Youtube could show you how to upgrade/switch RAM for a laptop.
Posted on Apr 02, 2015
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
How do you install RAM?
Installing RAM on the keyboard is just like installing RAM in your typical computer. Unscrew the plates off the bottom of the keyboard and underneath you will find two parellel slots (usually beige colored) for the memory chips to go in. Simply place the memory chip in the slot. The memory chip has to to be a specific type of memory chip, does not take regular computer RAM. You can find specific kinds on sites such as ebay. Just type "Korg triton RAM" in the search bar.
Jul 17, 2012 | Korg TR76 76 Key Synthesizer Workstation
I need to remove the keyboard to fit new memory how do i do this please
You do not remove the keyboard in order to fit your memory (Ram). You have to unscrew the bottom panel of your Laptop. Some laptops come with a section where you open at the bottom so that you can have easy access to fitting in memory. There is usually two panels at the bottom one for the Hard drive and the other for the memory. if you do not have this you then have to unscrew the whole bottom to get to the motherboard and then the memory itself.
Oct 20, 2011 | Computers & Internet
Toshiba laptop keyboard stops working
there are screws marked symbol of keyboard on the bottom side of laptop. unscrew them, carefully unlock the locks which are on sides of the keyboard. just slightly lift the key board. under the keyboard u will see that a cable is connected to the mother board. open the lock of the keyboard cable & put it again in socket. if k/b still not working u need to replace the keyboard.
Sep 21, 2011 | Compaq Keyboard
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
http://www.batterycentury.com/toshiba-tecra-m2v-s330-keyboard-p-79168.html
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
Sony vaio wont boot unless bottom unscrewed and ram pressed otherwise it powers but doesnt boot
The ram pins holding the ram onto the system board change that or get them tightened with a binding cord and that should solve the problem .
Oct 19, 2009 | Computers & Internet
Installing extra RAM on my Acer Travelmate 803LCi
No, the plastic strip should snap out. I generally lift up from the right side. Once I get the side up, I work the rest of it up and out.
Jul 11, 2008 | Computers & Internet
Installing ram
Flip the laptop over so that the bottom side is face up... you will need a Small Phillips head screwdriver ... Unscrew the cap to the RAM .. (it is the one that is generally the same size as the stick of ram going in it...).. slide it into the slot at an angle... about a 45 degree angle. then push the end downward towards the board until the latches lock it in place...rescrew the cap on the case ...
May 29, 2008 | Toshiba Satellite 2250XCDS Notebook
Inserting RAM in a Sony Vaio VGN-FE31H
Laptops have screws in the bottom of the laptops, but makesure you know what screws came out of whick ***** holes. Unscrew the ones yu need to undo the keyboard, put the ram in & ***** tem back in..
Let me know how it goes.
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
