Question about Stainless Refrigerators
Just bought a 2nd hand Mondial Elite Stainless Steel Freezer KICNX40 eletric thermestat is not working,how do i mke it colder
  • Stainless Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors, ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 07, 2015
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
SOURCE: ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Posted on Aug 07, 2008
  • 66 Answers
SOURCE: freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Posted on Nov 14, 2008
MNTECH
  • 1543 Answers
SOURCE: Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
Posted on Dec 07, 2008
My frigo is not colding much and the freezer not freezing
Adjust the thermostat to a higher number for a colder setting. You cannot turn off the refrigerator without turning off the freezer too.
Sep 14, 2015 | Fisher & Paykel RF170ADX4 ActiveSmart...
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Freezer is getting colder and refridg is getting warmer thanks marty
Dear your fridge's refrigerant is leaking get it checked by techecian
Oct 25, 2010 | GE Profile Arctica Stainless Steel Top...
On my GE refrigerator freezer PDS20SBRLSS, the temperature controls do not work. They are blank (LCDs not lit) even when I press the "colder" or "warmer" buttons. Help?
We will need to test voltage on rear of refrigerator by removing 8" X10" motherboard cover. If you still have low voltage there the the temperature board needs replaced. Let me know when ready to test, Sea Breeze
Apr 16, 2010 | GE PDS20SBRLSS Stainless Steel Bottom...
Kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Dec 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
65 people viewed this question
Top Stainless Refrigerators Experts
billconfused
richie46
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
