Question about Gcv160 Gas Engine
Problem Starting Mower
I put my carburetor back on after checking the float due to petrol in air filter. The engine brake works. The lever is deployed when I push the dead man's handle, but I cannot pull the cord. Cut lawn prior to leak.
  • 52 Answers
If the brake cable does not disengage the brake all the way the pull cord will not work properly.It will seem stuck.
Posted on Apr 02, 2015
Testimonial: "Thank you for your help it is appreciated. i am a little concerned that this has happened post fuel in the filter and exhaust. I put new oil checking that it was up to the top of the gauge at the start of the season and checked the air filter and spark plug. It started and I was very pleased. I noticed however that it was using an awful lot of petrol. I then noticed that fuel was coming through the air filter and exhaust. The carb was cleaned thoroughly last year by a professional so I was surprised that it could be a stuck float in the carb. I took the carb off and reseated the float and put it back on. I now find that I cannot deploy the cord. I have had the cord mounting off and it works fine when not engaged on the engine. The break works as I have deployed the dead man's handle and the lever goes backwards and forwards. It completes the movement so I cannot tell whether it should engage further. I have taken the spark plug out to see if I can move the blade but I cannot. I didn't hit anything prior to me noticing the petrol coming through the filter. I made sure to tilt the machine the correct way as this was instilled into me by my husband when I cleaned the underside. You are saying it could be the break but how can I tell when it appears to be completing the movement and it was not playing up prior to the petrol in the filter. It makes me wonder whether oil has got into the cylinders and is restricting movement. I don't know much about engines but how can I tell whether the break is engaged fully?"
Why does my float keep sticking on my Honda GCV160e lawn mower engine even after fitting a new carburetor?
I found a break down of the carby and I am wondering if the needle has been correctly assembled back to the float tang
there should be a small spring that attaches the needle to the float with a smaller in in the end of the needle that is coil spring loaded
This set is to provide a manual release of the needle of the seat when the fuel level falls and so prevents sticking and the coil spring arrangement is to prevent the needle allowing fuel in from the ripples in the fuel as it vibrates
Yes you bought a new carby and it ran well
However there may have been a hair in the fuel and that caused a problem that you sought to fix by taking it to a garage rather that a mower repair shop
garage mechanics seldom have an intimate knowledge of small engines and so reassembly of the carby may miss setting the needle to the float correctly
As to fuel gums etc , I would discount that as it is not old enough and left sitting long enough for that to occur
fuel left for long periods (6 months or more ) does deteriorate but an fuel stabilizer additive ( from any auto spares shop) will overcome that problem
My suggestion is that you fit an inline fuel filter to the tank hose and have the carby inspected by a honda small engine ( mower shop) to ensure that it is as was originally purchased
Oct 16, 2015 | Gcv160 Gas Engine
Why is my air filter on lawn mower saturated with gas?
Probably your Carburetor float seal is leaking inside. Have someone check your Carb.
May 28, 2014 | Toro Lawn Mower With Toro Power Tools
Gas run out of carberator when running
Hi james
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
May 02, 2013 | Karcher 2500 PSI Pressure Washer
I have a 2005 MTD 139 cc 21 inch cut mower (OHV engine) which runs for a few seconds, but then quits. This is a mower which I found, so I have on idea of its history. The gas had turned into the nasty...
Still sounds like you fuel problem. could have a clogged port in the carburetor or a sticking needle valve. pull the carburetor bowl with gas line still attached and make sure there is fuel flow as the float drops down. Spray carburetor cleaner through all carburetor ports.
Oct 23, 2017 | Yard Machines 11A-020B000 20-Inch 148cc...
My lawn mower starts and runs. Then dies slowly or lose of power. I keep replacing spark plugs on it. The burn up extremely fast. Mowes great at first then goes down hill. What should i do?
Hi hanksjosh01
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sep 06, 2011 | Poulan "Poulan" Push Mower
I have craftman lawn mower it has honda motor gcv160. i had old fuel in the tank now i try to start my lawn mower but doesn't start. i changed sparkplug but didn't work. then i had to clean the...
Hi islamamin200..
You have a problem with the inlet float, there is something holding it from closing totally.
When you cleaned the carburetor did you clean it with a cleaning solution such as lacquer thinner, this is used to cut the "varnish" buildup in the jets and needle valves of the carburetor.
Follow the directions below:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
May 26, 2011 | Craftsman Garden
Ariens A173K22 self-propelled. Fill up before starting, Do not overfill won't start, air filter soaked and engine flooded. Remove filter and will grudgingly start. Ok after that. Why is engine...
Your engine is flooding because you probably have some debris under the inlet float needle valve causing the carburetor to flood as you described.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
This is a FREE answer,Please rate me
Oct 10, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
My petrol mower starts then cuts out all the time it has oil and petrol so what could be the problem please?
Check your fuel filter if you have one.
Oct 04, 2010 | Garden
Wont start
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
There is a proper way to start the engine. Four controls are on your bike to assist in starting.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Jun 28, 2009 | 1992 Gilera Saturno Bialbero
Gcv160 Gas Engine Logo
71 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
