What does error 30 mean on a lavamac 10 washing machine please
SOURCE: error code tricity bendix aw1200w washing machine
I think this is a problem with the thermister (built in to the heating element assembly).
Posted on Jul 27, 2008
  • 3 Answers
SOURCE: My washing machine
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Posted on Mar 25, 2009
Daniel S
  • 4323 Answers
SOURCE: Error message F-10
Hi
Error Code F10 means Pressure switch not sensing correctly. Plesae check for the inlet water pressure. If water pressure is OK then there is an issue with the water inlet valve or pressure switch. Make sure the pipes aren't kinked or clogged. Please post back for any further assistance.
Daniel
Posted on Aug 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: hiaer hw-c1270tve-u washing machine error code 8
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
caroldon
  • 17129 Answers
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Posted on Nov 21, 2011
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
Hello, does anyone know how to fix "water in cage 60C:level 16" error message on a Lavamac AF180 washing machine please?
Check to see if there is any blockage in the pump or any water lying on the inside of the cabinet. I don't know much about Lavamac,s but some machines have a safety overflow tank in the bottom of the machine. If it floods or has a leak, it fills this tray and will call up an error message.
Nov 20, 2016 | Washing Machines
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
What does the error F27 mean?
something is blocked sud remove or some other thing like a filter needs cleaned or serviced
F20-30 on most means evacuation so pump filters etc
or intake is too slow
its a time error with an event
so,,,
Aug 07, 2014 | Siemens Washing Machines
Siemens WM14S392GB - error F61. Help to fix please.
Error E61 means that the door is locked but the sensor is showing as still open.
You may have a faulty door sensor.
May 07, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
I have had fault code 10 come up on the machine. Also reads require service
Hi just read your posting.Could you please supply the model number of your machine which is located on a sticker at the back of the machine up top.Error Code 10 means your fault on your machine is Thermistor Error.Please reply with model number and I can guide you throe the steps to rectify this fault.
Aug 09, 2010 | Fisher and Paykel Washing Machines
Error message F-10
Hi
Daniel
Aug 01, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
