Question about Invicta 8942 Wrist Watch for Women
The crown does not screw in and lock down it just turns .the watch is brand new not yet used
    New Friend:
    Problem Solver:
  • 9 Answers
SEND IT BACK.
Posted on Oct 18, 2016
How do I set the time?
Hi Charles,
I presume you're referring to a chronometer watch?
You need to twist the crown (little screw on the right side of the piece) counter clockwise until it slightly pops out. This is position 1. You need to pull the crown outward gently until you feel a lug sensation. This is position 2. Turn the crown to adjust the 'date' until you reach yesterday's date (one date before what you actually want). Then pull the crown outward again feeling that lug sensation. This is position 3. Turn the crown so the minute-hand swings in the normal movement of time (don't swing it backwards). Keep doing this until the 'date' turns to the current date. Now your piece is set on the correct date and the minute-hand is in the "a.m." Now keep turning the crown until you've reach the current time (noting the am/pm period you want). Push the crown inward to Position 2, then to Position 1. Turn the crown while in Position 1 to wind the spring. How many times depends on your brand, mine is 35-40 turns. Once I am done, push in the crown and turn simultaneously to lock it down. It will stop when it is seated properly.
Good luck.
Mar 10, 2015 | Watches
Casio edifice EF527D-1AV
Do you realize that this watch has a screw down crown to keep it waterproof?
Hold it in and turn it clockwise to lock it down.
Let me know if this helps.
Mar 11, 2014 | Casio Mens EF527D-1AV Edifice Stainless...
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 | Watches
Cannot set time for time for tag heure CL111a
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch. Nice watch, Michael
Nov 05, 2011 | Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    My watch is not working and it is brand new. do
    Look very carefully just under the crown (winder knob) for a piece of plastic used to keep the stem from being all the way down to start the watch. Remove that small piece of plastic, press down the crown and the watch should start. mcdevito75
    May 28, 2010 | Skagen Alarm Function Leather 519XLSL1...
    Screw down crown wont lock
    There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
    Rate me, plz.
    Jan 06, 2010 | Watches
    Crown will not screw down
    The model 3001 does not have a screw down crown, but is just as water resistant as a screw down style
    Dec 16, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
    Can you please tell me how to set my Rolex Oyster Perpetual Datejust? Day light savings toime ends this evening and the watch needs to be set back 1 hour.
    Unscrew the crown and then pull the crown out to the second click and turn. When done push the crown back in and screw the crown back down.
    It is very important to screw the crown back down. If this is not done the watch is NOT water resistant.
    Hope this helps.
    Ken
    Yellowstone Watch Inc.
    www.yellowstonewatch.com
    Oct 31, 2009 | Rolex Datejust SS
    How do i lock the-the crown
    If it has a screw down crown then depress and rotate clockwise until tight. If not you can't lock it down.
    Jul 11, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
    Invicta 8942 Wrist Watch for Women Logo
    Top Invicta Watches Experts
    Ansel Alberto
    Ansel Alberto
    deton8 von Splosion
    Are you an Invicta Watch Expert? Answer questions, earn points and help others
