Question about Toshiba E-studio 281c Copier
What can i do if my copier is not giving clear copies
  • Toshiba Master
  • 1,087 Answers
Depends what you mean by 'not clear copies'? Is this in copying or printing?
If not clear whenh copying, try cleaning the glass.
If it is not clear colour copies,because the colors are not superimposed accurately it may be you need to align the color system (see Printer Services)
If it black text, it may be the same reason, or a new cartridge or ink supply is needed. Ot it may need a good clean up on the roller or drums, or maybe just old age.
Posted on Apr 03, 2015
No copies or clean paper with no signs of copy on my kyocera km 1635 copier can you help me with these ? tnx a lot
try to make a copy from your PC,if it was working fine that means you have a problem with your scanner unit.
Mar 08, 2016 | Kyocera Office Equipment & Supplies
What can i do for toshiba 281c if it not giving clear copies?
replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Apr 04, 2015 | Toshiba E-studio 281c Copier
Dear sir Now my Toshiba copier e studio 600. It starts copy not clear in the text paper. However, I set bg adjustment and sharp option in the copier. It is still not clear for copying. Does it occurs by...
This might be for few reasons
Dirty optical glass
Developer
Drum
If lines on print it might be from fuser section
Can you give me details of print exactly
Feb 05, 2015 | Sharp Office Equipment & Supplies
Hi my copier text f2 code and i chang tuner but not worked plz give any reset code
Replace the developing unit. Use SIM 25 - 1 to perform stirring. in quick successetion place 'clear' 'auto' 'clear' then 25 and copy key.
Aug 01, 2011 | Sharp AR-5320 Black and White Copier
Actually machine is giving code 0001
go to service mode by pressing additional function 28 additional function .then go to clear and press ok to clear the error. if it clears then ok ,if not u have to check the fuser unit for drive.sometimes the lower roller bush gets out of position and this error is caused while copying
Jul 30, 2011 | Canon iR 2016i Black and White Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
We are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
Feb 17, 2010 | Sharp AR-M355U Copier
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
XC-830 copier Displays fault code H-3
Give this a try , if it continues you will have to replace the fuser.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy
Aug 07, 2008 | Xerox Office Equipment & Supplies
Toshiba E-studio 281c Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
