Question about Krups 408-75 Electric Blades Grinder
Motor works and turns blades but only when empty or nearly empty.
I'm trying to get inside but seems like the blades are not designed to be taken off? is there a knack maybe? it seems like the motor is mounted on the base and the side casing would slide off if i could get the blades off. The model number is F203, it is 200W.
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
Motor hums but fan blades will not turn
If motor hums and does not spin, then motor has gone bad.
As motors get older, the motor begin to slow down.
Motors are designed to pull-in cool air across spinning coils inside the rotor.
Once the motor slows down, the motor no longer gets cool air, so it gets hotter, and then overheats, and then rotor no longer spins.
In years past, motors were taken to local electric shop for rewinding Then the motor went back into service.
Today, the motor is thrown in the landfill unless recycled at local scrap metal dealer.
It's a waste that we no longer have small repai9r shops to fix consumer goods like fans, and instead the economy causes us to import another motor because it's cheaper.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 25, 2012 | FlowPro High Velocity Floor Fan 18in.,...
How do I get the fan off the fan blades in a 1994 dodge spirit?
If the OEM version is designed to be taken apart, there is a clip that holds the fan blade onto the motor shaft.
Its easier to buy the fan blade and motor together.
Jul 13, 2012 | Dodge Spirit Cars & Trucks
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
I changed the wiper motor out.  They worked without the blades on, but after installing the blades they tried to move down toward the hood.  I think the motor still works but it seems the shafts are just...
you may of fitted the blades when the wiper motor wasnt in park
ok remove wiper arms turn ignition on turn on wipers then turn of by wiper swicth not key motor will stop in park position fit wiper arms in positon try and your done
Jan 08, 2009 | 1997 Acura TL Series
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Krups 408-75 Electric Blades Grinder Logo
205 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
