Question about Pure Jongo T6 Wireless Speaker
I have a brand new PURE JONGO T6 that will not be recognised by my BT HUB 5. Is there a way to correct this?
How do I turn off smart set up on BT home hub 4?
Switching Smart Setup on and off on the BT Home Hub 4 or Hub 5
  1. Click on Advanced Settings.
  2. Enter the admin password. ...
  3. Click on Continue to Advanced Settings.
  4. Click on Home Network and then Smart Setup.
  5. Click the appropriate radio button to turn Smart Setup on or off and then click Apply.
Aug 12, 2016 | Computers & Internet
How do i get a user manual for my Lenovo tablet please
Everything is available online these days, or with BT you pay them a fee and they come and do it for you.
Lenovo User Guide
http://www.lenovo.com/shop/americas/content/user_guides/tptablet_ug_en.pdf
And your BT Hub details are here.
http://bt.custhelp.com/app/answers/detail/a_id/46549/~/bt-home-hub-5-%7C-bt
BT Home Hub 5 BT
Apr 03, 2016 | Computers & Internet
Will not connect with BT hub type 5
https://s3-us-west-2.amazonaws.com/customerdocumentation/Fire+TV+Stick+User+Guide.pdf
Page 35
You may need to assign an ip address to the firestick and a Wep or WPA password that the Bt hub is requiring.
http://bt.custhelp.com/app/answers/detail/a_id/11383/c/346,1887
If you decide to go with a static ip address for the stick make sure it is not leased out and assigned by the bt hub DCHP server
May 16, 2015 | Amazon Fire TV Stick
Will not connect to BT HUB 5
Power cycle and try again. Ensure BT passkey is correct.
Motorola Support
Jan 29, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
My printer has stopped communicating with our BT home hub It was OK and the security code is correct it just cannot establish a connection. I tried it with the previous Netgear wi fi and it connects just...
you can also change the BT home hub 2.0(black)encryption type to WEP type. all you need to do is follow the steps to change the type of encryption to WEP.
  • connect a computer using the ethernet cable to the hub(its the black cable with yellow leads).
  • open an internet explorer or anyother browser, in the address bar just type 192.168.1.254.
  • you will be getting the BT home hub manager page with please reset your password, asking for three credentials.
  • in the first bar enter the default admin password or the admin password which is found in the wireless card or at the back of the home hub in the label. in the second and third bars enter the password of your own, something like admin1.
  • you will be getting another page coming with four options at the top (home, services, settings and troubleshooting).
  • click on settings, and below troubleshooting in the blue bar itself , you will see advanced settings. click on it.
  • then click on continue to advanced settings, now below home in the blue bar itself, click on wireless.
  • after you do that, you will see two options called as configuration and security. click on security. there you will see the option to change the wireless encryption to WEP.after changing the type to WEP, type the same password again in the section for password and click on apply to save changes.
  • check whether your printer is connecting to your home hub after that,
I am a person who work for BT in the tech help desk dept. if you have any trouble in doing this please reply to this message
May 19, 2010 | Kodak ESP 5 Printer
Cant get itouch to connect to internet even though bt hub etc all in correctly
If it's connected to your wi-fi connection and it's not working then there's something wrong with the BT hub if it's not connected to the wi-fi then it has to be a problem with that , try unplugging it and leave it for 5 mins and plug it back in and try it then . that usually works for me Hope this helps.
Apr 16, 2010 | Apple iPod touch
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Pure Jongo T6 Wireless Speaker Logo
62 people viewed this question
Top Pure Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Audio Player and Recorder Expert? Answer questions, earn points and help others
