Question about RCA Audio Players & Recorders
What is open error 255 on my rca stereo? - RCA Audio Players & Recorders
Is my Panasonic cq-c7105u... Bluetooth ready, or how do I plug an auxiliary from my phone? (I recently bought a car with this stereo already in, and I'm tryin to play music from my phone.)
No Bluetooth built-in.
There is an optional part for this.
This unit has an AUX input from a pigtail connection on the rear of the unit. There are 2 RCA jacks, so you would need an adapter for your iPod/MP3 device.
The unit is also listed to be MP3/WMA compliant for discs:
"The CQ-C7105U can play MP3, WMA, and AAC files recorded onto CD-R and CD-RW discs in ISO 9660 Level 1/Level 2, Apple Extension to ISO 9660, Joliet, and Romeo. The player can support up to 511 files (files and folders), 255 files in one folder, 8 levels, and 255 folders"
Dec 29, 2014 | Car Audio & Video
Cant listen to radio & getting an open error 255
The mistake that throws you is that it has fault in the tuner of radio oi also it can be that not esten programmed the issuers
May 31, 2011 | RCA RS2664 Shelf System
Open err 255
are u sure its not the code
Jul 23, 2009 | RCA RS2664 Shelf System
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Open error 255
pls check supply voltage to tuner circuit,since this is digital tuner check digital clock and data.if you dont have scope to check,may be you try with vom meter and check about 4.7v on both line.when you select tuner notice slight flicker on your metre which will give hint of clock and data present.
Dec 16, 2007 | RCA RS2664 Shelf System
83 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
