What engine size? how many miles on the vehicle?
1: Leaking Water pump - How do I notice this in the car ?
Typically you will see a lot of dried up coolant around the water pump. If the coolant level gets low enough it will cause the vehicle to over heat and potentially do a lot of damage.
Water pumps are extremely common on these years.
2. Under Steering components it says Rack is Leaking, Passenger bellow torn open.
The rack is the part that turns the wheels left and right. If a bellow is torn and there is fluid coming out of it than the seals in the rack have gone bad. Eventually enough fluid will leak out and cause the power steering to no longer work and possibly ruin the power steering pump.
3. LF Strut /stunt is seeping.
It means that the oil on the strut is starting to leak out. The strut is what absorbs the bumps in the road and holds your tires down on the road. Eventually the strut will loose its ability to do this and the tires will start to cup. It is not uncommon for struts to show signs of leaking and is usually the first indicator that the strut is starting to fail.
Hope that helped.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/jeremy_d728a59f986299fa
