Question about Mitsubishi WD Televison & Video
The model is WD-52627, the screen flickered and then turned a light green and lavender. We still see the tv show
    Master:
  • Mitsubishi Master
  • 495 Answers
You most likely have a failing color wheel.this is a symptom of the color wheel losing sync. This is a common failure on a Mitsubishi TV of that age. you may be able to solve this by merely cleaning the insides. Unplug the TV and make sure the lamp has been off for at least an hour. Remove the lamp and use canned air or air compressor to blow inside the lamp cavity. Then have a vacuum ready to suck up any dust that billows out. The dust gets in the way of the color wheel sensor and causes this to happen. Reinstall the lamp and try again. If it does not let up, then you may have a bad color wheel or a problem with leaking capacitors in the power supply. With either of those issues you need a service tech to check it.
Posted on Apr 02, 2015
  • Mitsubishi Master
  • 1,150 Answers
Hi Jenell
Looks like you might have lost one of your primary colours. RGB
A section of the internal electronics controls Red Green Blue.
Check for loose plugged in cables on back. Antenna or Cable
Try inputing a signal from another external video device like a hard drive.
Try a couple of hard slaps on the back to see if it changes.
If it does then you may simply have an internal bad connector or loose wire.
Make sure the air holes around the unit are clean to allow cooling air to flow.
Other than that, you will need a technician to open it up.
Cheers
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
WD-52627 not showing programs in HD (showing in 480 not 1080) after moving and switching from DishNet to cable.
You have to change the composite inputs from the cable box to the one marked 1080p in the back of the TV. (The Green Red and Blue cables.)
Jun 19, 2011 | Mitsubishi WD-62526 Projection TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking Green Light on Mitsubishi DLP 52525
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Light engine problem?
sounds like your ballast is bad let me know your model number and I should be able to help you
Apr 11, 2008 | Mitsubishi WD-52627 52" Television
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
