Question about Crafts & Hobbies
How do I change the cutters on a B&D DN 710 planer
  • 514 Answers
OK, from the EU website at "http://service.blackanddecker.co.uk//Products/DocumentFull.aspx?ProductID=949&DocumentID=9973&BOMRegionID=1"
is this pic:
How do I change the cutters on a B&D DN 710 planer - 25622905-nejbjik3oh2kxijsmdkj2b3d-3-0.gif the only difference there should be here is that the EU model runs on 220V instead of 110V, good luck!!
Posted on Apr 02, 2015
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
How change blades in a makita 1912B
Power OFF. Unplug from the wall! If you screw up, it'll eat the fingers right off your hand!
Each cutter should have two bolts. Rotate the cutterhead with your fingertips until you can see them. Loosen and remove them. Remove the cutter. Replace, replace the bolts, and torque them tight. Never EVER leave the tool lying with a bolt loose! If someone mistakenly plugs it in and turns it on the cutter will fly across the room like wartime shrapnel.
Mar 09, 2014 | Makita 1912B 4 - 3/8'' Planer
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Sniping
You get sniping with all planers and it will always be the length from the cutter head to the second feed roller. Until the board goes under the second roller it is almost impossible to feed it through and not get some sniping. The same applies to the outfeed side also. Better made (more expensive) planers, table extensions and holding up on the end of the board until the other end is under the second feed roller will reduce sniping somewhat but you'll always have some sniping.
Mar 03, 2013 | Delta TP305 12 - 1/2" Portable Planer
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Planer or Jointer
If I had to pick, I would get the planer first. That way you can at least get your lumber pretty darn close to flat and parallel. Furthermore you can resize your lumber when necessary. But that’s just my opinion.
Aug 27, 2008 | Rockler 24? Precision Straight Edge
Crafts & Hobbies Logo
715 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
