Question about E-Machines eMachines Desktop PC
Emachine T4060 power supply
Should fan run disconnected from mother board
  • 31 Answers
I have to assume you mean
Will the cooling fans run if it is still powered by mother board and disconencted from the mount ,such as processor or chipset ??
Yes it would , but is a very dangerous thing to do ,as it could easily short against anything within the case
Be more specific with your problem maybe someone can help you better
Posted on Nov 14, 2007
  • Jim UnTold
    Jim UnTold Nov 14, 2007
    If you mean will the power supply fan run with the big 20 pin connection loose from motherboard then answer is NO
My computer has no signal
Hello, Sounds like you don't have the right power supply, only and emachine power supply from emachines will work.
Feb 22, 2014 | E-Machines eMachines Desktop PC
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
Emachines T3958 will not turn on
Check the fuse on the inside of it and see if it is not blown, if not blown change it any way it may not look like it is blown but it is hard to tell, and see if that work.
Jul 10, 2009 | E-Machines eMachines Refurbished EMA...
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
My T4060 will not come on
Hello m_dmiller,
There could be many reasons why the T4060 will not come on. The most obvious reason would be that it's not plugged in. But since it probably is plugged in there could be a failed power switch, power supply problem, hard drive failure or many other causes including a motherboard failure. The computer should probably be tested by a qualified technician to determine if it's worth saving. Sorry, but I'm unable to get the computer to come up without running the proper diagnostic tests.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Dec 29, 2008 | E-Machines eMachines Refurbished EMA VG31...
Emachine T4060
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
ps: if the mainboard bottom was in touch with anything metal from the case otherwise it might get damaged
Nov 13, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
