My techwood freeview box was working i feel aaleep n woke to a black screen & my freeview box appears to be atuck in standby mode. Can you help please?
  • 1,150 Answers
Hi Yvonne
"FreeView"
You must be in Australia. Like me.
I would assume that you have pulled the power out & reset the unit. I don't have the freeview box but they can be similar to other set top boxes.
Does the user manual indicate that holding down certain buttons on startup will cause a reset?
Some of these units have an internal backup battery to keep your parameters in memory. Often not user accessible.
But in emergency, the battery (if you find it) can be given a quick short with a jumper wire to reset it.
Otherwise You might need a tech to look at it or swap it out
Good Luck
Posted on Apr 02, 2015
bestdarngood
  • 3037 Answers
SOURCE: techwood twp 4210 media box
DEAD AV BOX NO POWER LIGHT
UNPLUG FROM THE MAINS
UNSCREW THE TOP CASE
UNPLUG THE 2 SOCKETS REF PICTURE ( TECHWOOD AV BOX RESET AND UNPLUG )
LEAVE THEM UNPLUGED AND “PLEASE BE CAREFUL AT THIS POINT” SWITCH THE MAINS BACK ON AND SWITCH THE POWER ON THE AV BOX, IF YOU GET A RED LIGHT SWITCH THE SET OFF.(PLEASE NOTE THE RED LIGHT MAY NO ALWAYS COME ON, SO DONT BE ALARMED).
PLUG BOTH THE LEADS BACK IN AND SCREW TOP CASE BACK.
CONNECT ALL BACK UP AND YOU SHOULD BE WORKING NOW
JOB DONE HARD RESET.
Let me know if you need any further help
thank you for using fixya and good luck
Posted on Apr 15, 2008
roety
  • 585 Answers
SOURCE: Techwood 32'' LCD, screen is black, no sound.
the light you see is the backlight, you have either a bad signal board or tcon board which is part of the screen usually.
only cheap solution may be if the capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1
try reseating the thick cable running to the panel (Tcon board) top center inside the set
Posted on Aug 01, 2009
SOURCE: got techwood 16822 tv cant find freeview chanels on it ?
I have a 168822 cant get any freeview channels is it my ariel ?
I have used and recieved freeview at my old address ?
Posted on Nov 29, 2009
SOURCE: Although the Freeview box is correctly installed
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
Posted on May 08, 2010
  • 78 Answers
SOURCE: techwood 26" cannot get no
contact your cable provider
Posted on Feb 01, 2011
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Techwood twp 4210 media box
Apr 15, 2008 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
May 08, 2010 | Televison & Video
My techwood 1020 freeview recorder was fully working but now theres no picture or sound and when you press buttons on the remote a little red key is flashing on the box its self. help me please
hi mines is doing same from digital switchover theres a red key flashing and it wont record,although i can still use it as a freeview box.i bought from morrisons but because its just over a year old they told me to phone techwood and techwood told me they only deal with tvs even though its a techwood help number on the box!!
Mar 06, 2010 | Televison & Video
Jul 26, 2009 | Televison & Video
Got techwood 16822 tv cant find freeview chanels on it ?
Jan 26, 2009 | Televison & Video
Techwood freeview
Any luck? I lost channel five to channel 802. I want to change it back to it's slot after channel 4
Jun 09, 2008 | Televison & Video
Freeview locked
Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
