My lcd screen is shaking.. it seem good when i open but after 3/4 minutes ..it is continuing to sacking.
  • 1,150 Answers
Possibly Overheating!
Posted on Apr 02, 2015
What is the difference between a stuff sack and a compression sack?
Your sleeping bag is usually sold with a stuff sack, which just refers to the (usually nylon) bag that the sleeping bag comes in. If space in your backpack is not an issue, than the provided stuff sack will be fine for you, but keep in mind that it is not totally waterproof because water can enter in through the opening at the top. A compression sack is a separate sack that you can buy if you want to pack your sleeping bag into a smaller size. The compression sack shrinks the size by allowing you to use straps to squeeze any excess air out of the sleeping bag. The straps are connected to a piece of fabric that can cover the opening of the sack and make it completely water-proof.
Dec 26, 2012 | Camping, Backpacking & Hiking
How are compression sacks waterproof? What about the opening where you shove the sleeping bag in?
There is a 'roll top lid' that covers the opening. After shoving your sleeping bag inside the sack, you place the lid over the opening. The lid has 4 straps that are connected to the bottom of the sack. Once the lid is in place, pull the 2 opposite straps at the same time. The lid is made out of the same waterproof fabric as the rest of the sack, sometimes it is even double insulated because it has more stress put on it. As long as you make sure the lid covers the entire opening, no water will be able to get in.
Laptop vaio screen weird lines down bottom bar
Th problem sounds like the LCD or Plasma inverter might be time for a change, but before you do that try this out..How to fix PC errors
Dec 18, 2011 | Sony VAIO Computers & Internet
Our pellet fire seems to take a long time to ignite and start flaming we are using a sack of pellets from last year can you helpp it is taking aboout 20 minutes to produce a small flame
I suspect that the sack of pellets left over from last year, have absorbed a lot of moisture during that time. Therefore, they are hard to light and slow to get up to a roaring flame. Really, there's not much you can do to correct this. Other than stop using that sack of pellets to get the fire started. Use a new fresh bag to start the fire and add the others to the hopper, after the fire gets really hot.
Hope this helps you.
May 17, 2011 | Heating & Cooling
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 14, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Icon of a shaking hand on LCD screen
The shaking hand icon has to do with the Image Stabilization control.
If it's continuously shaking, it's set in continuous mode, etc.
You can access control for the "I-S" via the menu...scroll down to IS settings. and you can adjust as desired.
Dec 10, 2009 | Canon Cameras
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
CAUTION:
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
