We have a CGN300TQ heater. We took it apart, cleaned it, and had the outer shell powder coated. We put it back together, but now, we have to light the pilot light and the gas burner will not catch.
Is this because of the powder coat or have we put something back together wrong?
    Top Expert:
  • 10,875 Answers
You might need to adjust the air on the pilot assembly,WARNING!!!,IF THE AIR IS NOT PROPERLY ADJUSTED AND YOU HAVE IT LIT,YOU CAN DIE FROM CARBON MONOXIDE POISONING!!!!!
call someone to adjust it,you may also need this part,
We have a CGN300TQ heater. We took it apart, clean - 25622876-nxh1yjb3zvj0xc14pvjgo4do-1-0.jpg
Posted on Apr 02, 2015
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
My son took his meade etx-70 apart can't remember which way objective lens is supposed to be facing down the tube when it came time to put it back together.
NEVER take a lens out of an eyepiece or telescope, only clean the outer surfaces.
Try putting the flat sides together and see if that works.
Apr 14, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Powder actuated tool wont fire. I think the firing pin is stuck
is this the one you hit with a hammer? if so check to see if the firing pin is hitting the shell rim at all, if it is sometimes you just have to hit it harder, and make sure your holding the shell in position with down pressure on the handle. if it is the gun model then make sure that the safety lever is is reaching the trip mechanism when you are holding it down making ready to fire.
Feb 05, 2009 | Remington Powder Actuated To Power Load...
Whenever I turn it on theres just a blue screen and I can't get it to record
It took me a while to figure this one out but I finally did and mine is back to working perfectly. The problem: The Play option worked fine but the camera did not. When turned to camera mode the blue canon screen would come up and then freeze. The only way to turn it off was to remove the battery.
The fix: I was brave enough to take the entire outer shell off the camera. On the main board, underneath the screen/battery side, all the different parts are connected together. There is a single connector from the lens that had come out of its port. The ribbon connector must have somehow been shaken out of the port at some point. With needle nose pliers I carefully fit the ribbon connector back into the port. I carefully reattached the outer shell and everything was back working!
I will warn you that this task takes some time due to many many screws. It's a lot better than sending it off for hundreds of dollars though.
Oct 12, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Dishwasher will not drain
We took it all the way apart and cleaned it really well in the bottom of the dishwasher. Then we put it back together. Then we removed the hose from the disposal and suctioned it with the wet/dry vac to remove any clogs, then put that back together.
Ran dishwasher with Tang in both powder cups to clean it, and it's running fine now.
Apr 20, 2008 | Dishwashers
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
