Question about Garden
Poor spark - Garden
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
Check plug gap, usually .030 inches for briggs and stratton engines. Bad coil or damaged coil wire (plug wire).
Posted on Apr 24, 2015
What's the cause of my car running poorly and shutting down?
There are a LOT of things that can cause your car to run poor and shut down but it sounds like you think the coolant system is the problem. If that was the case, your car would overheat.
Usually the first things to suspect are poor gas (like water in your gas), loose fitting spark plug wires, old spark plugs. If spark plugs and spark plug wires are good, you might suspect a fuel filter or even a fuel pump.
Apr 13, 2015 | Cars & Trucks
Opel monza gsi E16ES ECU pinout diagram
Unlikely this is being caused by ECU. Not impossible, but unlikely. For poor spark, ECU has nothing to do with this. Check ignition module/coil. For overfueling, bad spark can prevent burning fuel properly, but leaking fuel injectors or bad coolant temp sensor more probable.
Dec 27, 2014 | Opel Cars & Trucks
What do u do when spark is weak on Yamaha blaster
Check battery voltage, remove spark plug suppressor cap from HT lead and see if spark is good by holding lead in a gloved hand and placing the lead end near the engine. If spark good get a new suppressor cap. Check the plug shows a good spark in the new cap by holding the screw thread to the engine. Poor spark change spark plug. If you get a poor spark from the HT lead then get the ignition coil checked.
Oct 06, 2014 | Yamaha Motorcycles
2006 ford Escape - poor idling after starting
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you check the spark plugs. If the spark plugs have big gaps, corroded or covered with carbon you'll have poor fuel burning which can result to poor starting. If that's the case, I suggest that you replace the spark plugs.
Hope this helps and thank you for using FixYa! Have a good one!
Jun 08, 2011 | 2006 Ford Escape
Very poor throttle response in low gear....throttle response poor below 4000rpm
Please replace your spark plug with new one. Just use the recommended spark plug.
Apr 20, 2011 | 2000 kawasaki ZX-6R Ninja
Im sorry,its a 1997 ford 302 (1997 mercury mountaineer) codereader indicates 'no. 7 cylinder misfire'
remove the #7 spark plug if it does not look fouled start the vehicle with the plug still connected and look at the ground electrode for any spark it should be a white arc which indicates a high intensity spark if its orange/red it is a weak spark. If you get a poor spark try removing any other spark plug and test it on the #7 coil wire If you still get a poor spark then your plug wire or ignition coil is to blame and would need to be replaced. You can swap your plus wire to test it in the same way as well. hope this helps
Mar 05, 2011 | 1997 Mercury Mountaineer
Has fuel and spark but wont fire engine turns over so starter ok
If by what you mentioned is right the engine should fire but there is an issue and could be relative to poor intensity of spark, poor plugs, poor fuel delivery and finally poor TIMING.
So you need to check the above one by one to confirm the fault.
The use a good timing check is important, so also to check the spark plugs.
Feb 02, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
My 1996 xr 250r wont start drom the kickstart but it will start if you pushstart it can any one help me??
Hi
If the kick-start is seized or lacks resistance when you try to turn it then the mechanism will have to be investigated
If the kick-start feels normal, the spark is good when kicking her over & the performance is well down then there is probably a lack of compression
Ride Safe
Bike-Doc
Sep 29, 2010 | 1996 Honda XR 250 R
When do the spark plugs need changed
Spark plugs like any electrical device become worn over time. Spark plugs also work under extreme condition. The use of cheap fuels will leave deposits, poor maintenance, bad air filters, old plug wires, all these items can cause a spark plug to fail or not perform at its peak level. Also spark plugs use a gap or Electrical bridge that is used for high voltage to arc across. The larger the gap the hotter the spark until you reach a point that the coil can not bridge the gap and then you get a misfire. Also when a plug gets deposits from either oil, poor fuel, carbon this will shorten the gap and cause a weaker spark resulting in poor performance, wasted fuel and engine dieseling or Run on after the ignition is turned off.
These are the simple reasons for spark plug replacement.
Jul 19, 2010 | 2005 Dodge Caravan
I have a 1978 yz 125 with a poor spark. It won't stay running.
poor spark or poor compression, replace the spark plug cap (piece that goes on spark plug to coil wire)
Feb 07, 2010 | Yamaha YZ 125 Motorcycles
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
