Question about Hisense 55K22DG 55-inch 1080p 120Hz MHL & Roku Ready LED HDTV
My tv Won't turn on by pressing power button in tv,but if I unplug from outlet and turn on tv turns on like nothing happened.why?
    Top Expert:
  • Hisense Master
  • 74,243 Answers
SMPS start voltage section circuit has the problem. In most cases, it will be of start voltage supply resistor failure. Contact any service technician. The SMPS section circuit should troubleshoot. Electro help
Posted on Apr 02, 2015
  • Hisense Master
  • 1,150 Answers
Hi Uzziel
The power button is digital these days. That is... it does not have the AC power directly connected to it. Like a normal appliance.
It's a Computer.
Nowadays, the switchmode power supply module converts the incoming AC power to the lower DC voltages required by the other circuit boards.
It uses lots of Electrolytic Capacitors to clean up noise in the DC power. But one Electro Cap is used to store a charge for turning on the switch mode power supply. Being Electrolytic they are prone to leaking & bulging so they don't do their job. They won't hold a charge. By pulling the plug and restarting, you have found a way to overcome the problem. But only temporarily. When the Cap goes fully bad, you won't be able to start the TV any more. Suggest you order a switch mode power module for it or take it to a tech who will replace the module. It's usually in a metal shielded small box full of ventilation holes.
I have repaired many switch mode PS but most tech's these days don't bother. They just get a replacement.
Cheers
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Tv won't turn-on
ITS THE PICTURE TUBE ITS BURNT OUT - OR THE GAS HAS LEAKED OUT ANYWAY U NO LONGER CAN USE IT
Aug 22, 2007 | Hitachi (3223424A)
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Hisense 55K22DG 55-inch 1080p 120Hz MHL & Roku Ready LED HDTV Logo
124 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
