Question about HP LASERJET P1006 Printer
What Could Possibly The Problem?
The paper only passesby without any print. No sound as if there is evidence to be heard printing. And how to open it. Thanks in advance.
  • 52 Answers
Please unplug the printer, wait 2 minutes then plug back in.
Posted on Jul 10, 2015
SOURCE: Bogus paper jam
I had the SAME problem with my printer and after hours of searching on the web I found this solution on fixyourownprinter.com and it WORKED! I cleaned the contacts of both of the ink cartridges and then popped off the cover of the optical sensor on the side of the ink cartridges (black plastic cover over sensor assembly snaps off) there is a hole in the middle of the sensor, push it in with a thumb tack or toothpick and push up on sensor assembly and it will come off the side, clean the contacts on that and reassemble..the blue sensor light should come back on and you should be back in business.
Posted on Feb 05, 2008
EPIJAB
  • 89 Answers
SOURCE: printer not printing
If this printer has the duplexor feature there is a plate just above the paper tray and the paper may be stuck in there. Pull out the paper tray and look for a sorta blue button on the top right side inside of the printer. Push that button and the duplexor tray will drop down and that is where the paper may be hiding.
Posted on Feb 15, 2008
IrishDruid
  • 2712 Answers
SOURCE: Paper Jam
Just check the rollers for debris or any tiny piece of paper. Sometimes using refilled cartridges also can cause this error. Should that not work, you could try a hard reset: unplug printer from pc and mains. wait about 10-15 minutes and while holding down the power button, connect to mains and tho pc. Hopefully that should work.
Posted on May 11, 2008
  • 3 Answers
SOURCE: HP Officejet 7130 xi all in one say Bad Print Head
printer flashes lightes and instructs to turn off and on. When ask to print
Posted on Dec 19, 2008
  • 13433 Answers
SOURCE: paper jam
try this....
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Both paper jam and ink replacement lights are flashing.
Sounds like print cartridge collided with paper. Open both covers. Try to remove paper carefully without damaging print cartridge. you may need to remove print cartridges to get paper out. Then close every thing without print cartridge in. Reopen covers reinstall print cartridge/s, hopefully, everything returns to normal. It will probably say something about going through the process of realignment.
Mar 13, 2015 | Office Equipment & Supplies
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 12, 2012 | Canon PIXMA MP130 All-In-One InkJet...
I have a Xerox WorkCentre Pro 416. It has worked very good for several years. I was printing several pages and I heard a noise like something plastic broke and then I got the alarm with a paper jam...
sounds like the unit has an issue with one of the rollers not activating. contact a repair technition, any one worth their weight should be able to diagnose in a few hours. units with so many moving parts are hard to diagnose without visuals.
Mar 07, 2011 | Xerox WorkCentre Pro 416 All-In-One Laser...
How do I find and remove the printhead?
Here you go:
8. Close the inner cover and top cover. __________________
"If it's really a supercomputer, how come the bullets don't bounce off when I shoot it ?"
Jul 09, 2010 | Canon Office Equipment & Supplies
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I cannot remove the printhead to install a new one , afrain of breaking somethin
1.Confirm that the printer is powered on.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
HP LASERJET P1006 Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
