Question about Refrigerators
Frige is not working at all
Control board does not respond at all and just blinks the number 5 in both displays.
  • Refrigerators Master
  • 5,323 Answers
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 07, 2015
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
My TZ5I console was displaying numbers, but the machine would not respond or work. The speed would vary without touching any buttons. I held the stop button for a few seconds and the consile went blank....
There 2 possibilites that you must test:
1) test the voltages coming from Controller motor board
to the console, if there are the console is FAULTY!! replace
2) If there are NOT, voltage from controller motor board, this board is fAULTY rEPLACE
LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 22, 2018 | Nordic Track NordicTrack T5 zi Treadmill
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Frigidaire microwave model fmv152ksa Some of the buttons on the console do not work. The number 5 does not work (if I hit timer & any other #, the # will show up, but 5 will not show up) the clock on...
If you're saying that some digits or segments on the display do not light up, then I would first suspect grease or moisture on the control circuit board.
If it's just that some pads on the keypad will not respond, I would say your membrane keypad is failing.
I would first give it a "hard reset" by unplugging it for 2 minutes, then trying it again.
If it still fails, I would remove the control panel assembly (see the disassembly video here) and inspect the circuit board for green, gray, or white residue or grease.
The membrane keypad is not available as a separate part, but comes already installed on a new control panel frame, which is part number 5304464130 which you can order from the Pros here.
To replace that, you unplug the keypad (as per the photo below) and move your circuit board into your frame.
If you need more help, feel free to contact us directly.
Jan 27, 2011 | Frigidaire FMV152K Microwave Oven
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Frs6lc8fs3. freezer nor frige is working and flashes a #4 on the display.
On your model the digital controls are the main controls called a Genesis Control. It has 2 part numbers for the same part. 241739701 or 1196804 Digital Control
When compressor and fans are not running that control is the most likely reason. Reading #4 may be a failure code but looking over the wiring diagram there is really not much more that could be the reason for a fault failure code of that board. Shows that you still have voltage to the board but because everything is controlled from there like measuring the freezer and refrigerator temperatures, defrost and switching the compressor and fans off and on I believe your problem is there. Sorry about the troubles, Sea Breeze
Oct 15, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung rb1955sh
if you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Dec 20, 2008 | Samsung RB1955VQ Bottom Freezer...
All Display Lights are out, only HRS is flashing
I'll take a poke at this. First make sure someone has not hit the control lockout button. You will not be able to change numbers, that is if the control assembly has one. Another thing to try is unplug the unit and wait 5 mins and plug it back in and see if the controls resume operation. These unit also must have aproperly phased and grounded outlet to work properly.
Now if these don't work then most likely the control board is defective or the main board on back of the unit is defective. The good news is that even if the control board fails there a a failsafe mode the main board goes into and sets the temps at 0 and 37. hope this helps in some way.
Aug 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
