Question about Kenmore Refrigerators
Frige not working at all control panet is blinking double 5's and wont respond at all.
  • Kenmore Master
  • 5,323 Answers
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 08, 2015
SAMSUNG UA60H700 TV not powering up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 14, 2016 | Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
I have liftmaster profeesional. 2000sdr. need logic board and panet it connects to.
Double check your model number. It is on the end of the opener nearest the door.
Oct 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
Acer Aspire 5720, display no longer turns off
PLease go in control panet by pressing start buttan. Then click power option & change the sleep & stand by mode from there. Your problem will be solve then. Thanks.
Feb 28, 2010 | Acer Aspire 5720 6497 Laptop
Can't get PX-RC1 to work with my older JVC
sometimes the universal remote controls cannot recognice old codes try this general process for remote contrl 15-2142
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
popular code first.
responds.
blinks twice.
1 to 6, substituting the appropriate device
key.
Mar 05, 2009 | Radio Shack 15-2142 Remote Control
Rcr311w remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 13, 2008 | Universal Remote Control DIRECTV Universal...
Remote control #15-2147
Toshiba 0749, 1749, 0790, 1285
If that doesn't work then:
trying all codes listed for your brand, or if your brand
is not listed, try searching for your code. For example,
1. Press TV once.
then release.
code first.
blinks twice.
device.
IF that doesn't work, I know a great place to find sledge hammers.
Oct 04, 2007 | Radio Shack (15-2147) Remote Control
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
