Question about Microlife Health & Beauty
I m a doctor ,instrument is not working properly and repeatedly Error 5 is appearing,and cuff is not gettingfully inflated,though the batteries r OK,intimate repair centre in Delhi,India
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: No proper inflation,error3 appears repeatedly,btrys r OK,advise action or intimate name of repair Center in Delhi,India,I m a Doctor?
i sent you the link of the company,use it to contact them
Posted on Apr 02, 2015
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
Cuff does not get full inflated even after getting it properly applying error3 appears,I m a Doctor
replace batteries,or there is a leak,you didnt say which bp machine it was so go here and find your machine to get the user manual for it, Microlife Manuals
Apr 02, 2015 | Microlife Health & Beauty
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
Why does anOmron M7 Blood Pressure Monitor Cuff not fully inflate?
I have the BP760 model so I'm not entirely sure what the functionality differences would be. However from time to time I have had issues with the cuff not inflating. It is usually one of two things: the cuff is not positioned snugly enough on the arm (I have a skinny arm and sometimes need to enlist the help of a family member). The other time it has happened was when the inflation tube itself with so kinked and twisted that air could not flow through. You should also check to make sure that the inflation tube in securely connected to the unit. So make sure that the air supply from the cuff to the unit is not obstructed, and that the arm cuff is positioned properly and that you are not trying to put the cuff on over clothing. If you've checked all of this and/or you receive the error message of "Er", you should contact customer service. Hope this helps.
Aug 29, 2014 | Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Health & Beauty Logo
85 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
