Question about Equus Innova 3150 Abs / Srs Professional Canobd2 Diagnostic Code Scanner For Obdii Vehicles
How come i hooked up to a vehicle and the reader wouldnt read it
    Top Expert:
  • Equus Master
  • 10,875 Answers
INNOVA 3150 ABS
it doesnt read older cars etc,it states that on the box and the manual,
https://www.innova.com/Content/Support/Manual/Innova/Manual_3150b_E.pdf
how come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-0.png
25622823-nxh1yjb3zvj0xc14pvjgo4do-1-2.png how come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-5.pngt/uploads/images/25622823-nxh1yjb3zvj0xc14pvjgo4do-1-5.png" alt="25622823how come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-9.png"h_mi" />
how come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-20.pngages/25622823-nxh1yjb3zvj0xc14pvjgo4do-1-14.png" alt="25622823-nxh1yjb3zvjhow come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-27.png
25622823-nxh1yjb3zvj0xc14pvjghow come i hooked up to a vehicle and the reader w - 25622823-nxh1yjb3zvj0xc14pvjgo4do-1-54.png>
	 <img src=
Posted on Apr 02, 2015
The obc.computer reads error when hooking up to a 97 grand marquis will not read the codes what's wrong ?
OBC ? It's OBD 2 - on board diagnostics ! Could be a cheap code reader , an open on the wire that goes to the PCM from the DLC . The PCM may be bad ! Suggest you take your vehicle to a qualified repair shop .
Aug 08, 2016 | Cars & Trucks
How do I clear the 2a00 code on an 07 altima
you would need to find someone with an od11 reader. they will hook up to your vehicle read codes and clear them at same time
Dec 02, 2014 | Cars & Trucks
Why when i hook up an OBD2 code reader it doesnt come on at all like its not gettin power
If you have codes DO NOT CLEAR THEM
You will loose ALL DATA needed to find & resolve
any problems
You do not reset anything-you CLEAR DATA,Emission
Monitors,& Freeze Frame Data, that can tell you what happened
when a code or fault was set
If you clear codes, they will come back,as soon as the motor
is restarted ,or when those emission monitors run next time & do
so for a number of key cycles or until the problems are fixed
Forget Relays ever existed. They are like a plague that has spread
thought the internet
Please Google relays & learn what they are,They seldom fail &
NO Parts get replaced EVER Until a vehicles system has been
tested & a part fails a test
You DO NOT hang parts or throw parts at any vehicle
Only people with NO Vehicle knowledge do that, most folks
do that ,even some professionals at repair shops ,to the tune
of 3 Billion Dollars a year world wide in perfectly good parts
Explain in detail all of your vehicle problems
Explain what codes reader you have & what your doing
You plug it in under the dash & turn the ignition to the on
position & write down the codes, then push the up or down arrows
to see the next one
Read the codes reader manual
After that you start the vehicle & drive about 10 miles to see what happens--- with the code read still plugged in
If you could care less about fixing it ,clear the codes & see if the
same ones come back.
Once done ---you start all over at a repair shop & use professional
tools to do it correctly & find a problem
Jul 19, 2014 | 2002 Chevrolet TrailBlazer
I took for a smog check and the guy plugged in his computer and said it wouldnt read it
europeon import software no doubt,no europeon vehicle or very few can be read via the OBDII your inspector should put a probe up the exhaust to measure the emmisions not plug into the OBDII as connecting up to certain cars with a code reader will render the vehicle in a non start immobilised state that only a dealer can sort out as this is deemed to be illegal access to the OBDII where someone could be trying to by-pass the immobilisor via the OBDII .
Jun 26, 2011 | Honda CR-V Cars & Trucks
Where do i hook up the engine code reader on 89 ford tempo.t
The universal OBDII code reader came out in 1996 per government mandate. Before that time, OBDI was the first vehicles with computers, and every manufacture was doing their own thing and creating their own vehicle specific testers or using lights on the computer to read codes. So you will not be able to ready the codes on your pre '96 vehicle. You would have to take it to a shop that has the special equipment to read the codes or get a service manual with flow charts to walk you through reading the codes off the side of the computer. Hope this helps. Good luck :O)
Feb 17, 2011 | 1989 Ford Tempo
Engine light on sometimes 2006 trailblazer
Invest in an OBDII reader. They range in price from $20-$400 and can do anything from just read codes when the engine light goes on, to real time data. Intermitent engine lights are tough, so next time it goes on, you can hook up your reader and find out what it is right then and there. Even for future problems, you can keep your mechanic honest by knowing exactly what's wrong with the vehicle. Buying a code reader will pay for itself the first time you use it.
Feb 13, 2011 | 2006 Chevrolet Trailblazer
Will not shift into overdrive?
Hook up your On-Board Diagnostic (OBD) Reader and read the Diagnostic Trouble Codes (DTC's). Mine was P0500: Vehicle Speed Sensor (VSS) malfunction. After VSS replacement, all was fine.
Dec 03, 2010 | 1999 Lexus RX 300
Problem with Code reader not reading from 1998 jeep cherokee 4wd
the vehicle wouldn't run without the computer, it may be the code reader is not set up for your vehicle, especially if its a general reader
May 08, 2010 | 1998 Jeep Cherokee
Fuel problem
Most GM vehicles use the cigarette lighter fuse to power the data link connector. Better way to test a fuel problem is with a fuel pressure gauge. Code reader may give you a rich or lean cose but won't tell you why.
Apr 29, 2009 | 1997 Pontiac Firebird
Equus Innova 3150 Abs / Srs Professional Canobd2 Diagnostic Code Scanner For Obdii Vehicles Logo
156 people viewed this question
Top Equus Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
Are you an Equus Office Equipment and Supply Expert? Answer questions, earn points and help others
