Question about Car Audio & Video
How to install icbm 900.4 where do i mount - Car Audio & Video
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
I have the same sub on the "digital" amp from the same company.
I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Hey I just recently buy a performance teknique
    good luck finding one, check ebay, or call Teknique directly.
    Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
    Oil leaks past distributor mounting plate.
    I'm not sure of the exact procedure but you can try getting your hands on a Haynes Manual, they base the problem solving on a complete tear down and rebuild of the cars, and they have one for a 1997 Saab 900.
    May 25, 2009 | 1997 Saab 900
    Performance teknique icbm-782 amplifier will not power on
    run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
    Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
    Performance teknique icbm-896 stick on diagnostics
    If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
    Amp in Protect Mode - Troubleshooting
    Let me know if you have any other questions.
    Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
    Car Audio & Video Logo
    64 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
