Question about Miscellaneous
I got a dark patch in back of my ear it itches and gets scaley also has white heads. When I squeeze it heads come out and clear fluid??
  • 696 Answers
Time to head for the Doctor. Possibly basal cell carcinoma.
Posted on Apr 02, 2015
Itching and dry patches on palms of hands
Itchy Palms: What's the Cause? - Healthline
https://www.healthline.com/health/itchy-palms
Apr 12, 2017 - Eczema. Atopic dermatitis, or eczema as it's sometimes called, is a condition that makes your skin itch. It may cause colored patches of skin in the affected area. ... The skin may also be dry. ‎Causes · ‎Additional symptoms · ‎Treatment
Hand dermatitis ' DermNet New Zealand
https://www.dermnetnz.org/topics/hand-dermatitis/ ... the palms or both. It can be very itchy, often burns, and is sometimes painful. It has acute, relapsing and chronic phases. Acute hand dermatitis presents with: Red macules, papules and plaques; Swelling; Blistering and weeping; Fissuring. Features of chronic hand dermatitis include: Dryness and scale; Lichenification. ‎Emollients and moisturisers · ‎Allergic contact dermatitis · ‎Irritant contact dermatitis
Hand Eczema ' Treatment ' Triggers ' Causes ' Dyshidrotic
https://nationaleczema.org/eczema/types-of-eczema/hand-eczema All types of eczema cause itching and redness of the skin. But some, like hand eczema, look and act slightly different than others. There is another specific type of hand eczema called pompholyx or dyshidrotic eczema, which causes small, itchy blisters to appear on the palms of the hands.
What's Causing My Itchy Hands and Feet? - WebMD
https://www.webmd.com > Skin Problems and Treatments > Reference Jan 11, 2017 - Dry skin can make your hands and feet itchy. ... There are a few different types, and itchiness of the palms and soles is a common symptom. ... Patches of red skin, bumps filled with gunk, or silver scales; Painful, swollen, or stiff joints; Soreness of the affected area; Itchiness in other places like your elbows, ...
The palm of the hand ' GPonline
https://www.gponline.com/palm-hand/dermatology/article/907484 May 29, 2009 - The patient notices a gradual area of dry, itchy, peeling skin on the palm and a 'powdery filling' in the skin creases. Sometimes blisters form. Skin scrapings for microscopy and culture should confirm the diagnosis of the fungal infection. Patients may have other affected areas. A topical antifungal preparation ...
Dry, scaly, and painful hands could be hand eczema ' American ...
https://www.aad.org/public/diseases/eczema/hand-eczema You may have more than dry skin. Hand eczema could be the culprit. Hand eczema can cause the following: Dry, chapped skin (often the first sign); Patches of red (or dark brown) irritated skin; Scaly and inflamed skin that may itch; Burning sensation; Itchy blisters; Deep, painful cracks; Bleeding or weeping skin; Crusts, ...
Itching and dry patches on palms of hands Google Search
Dec 11, 2017 | Computers & Internet
White smoke belching out but will not start
white smoke is usually water, grey=oil dark grey=other fluids. with the belching and other symptoms i would be inclined to believe you have a blown head gasket.
Nov 15, 2011 | Cars & Trucks
I have a 65 inch syntax brillian TV. The picture is pretty dark, and I'd like to clean the mirrors and lenses. How do I do that?
Shannon, cleaning the mirror or the lens will only drgrade the picture that's reflected onto the screen. A dark picture is most likely caused by the ~300 watt lamp aging and now needs replacement. You can confirm this for yourself by removing the lamp from behind the right hand speaker door and looking at the bulb-shape at the inside, bottom of the reflector. The bulb should be clear, with maybe a small white patch on the top of the inside of the electrod chamber. If it's a large white patch, or the chamber has any black, or even worse has a deformed chamber, the lamp only needs to be replaced.
I did the longevity testing for the 65" TV's. No other component caused the TV to 'darken' as you state....
Jun 19, 2011 | Syntax-Brillian 247T FHD 47 in. LCD TV
Where is the temp sensor located on a 1999 saturn
The engine coolant temperature sensor is located on the driver's side of the head of the engine. Look for the upper radiator hose going into the head of the block. It is just behind and underneath it. You will have to take off the air intake tubing. It has two wires going to it (black and white I believe off the top of my head) and goes into a connector. Squeeze the connector at the "ears" and it pops off. Under the connector is the temp sensor. A 10MM DEEP well socket will take it off.
Jan 27, 2010 | Saturn SC2 Cars & Trucks
White Smoke out of the exhaust when excelarting And difficuly getting into gear between 40-50 miles per hour sticking or hesitating
Hello! The white exhaust smoke is indicative of coolant/water being mixed with the engine oil, and the white smoke is the byproduct of it being burned off. Unfortunately, this is a problem, as coolant shouldn't be mixing with oil. Possible causes are a failed head gasket, or cracked head. The first thing you can do is check the oil dipstick - you're looking for a milky brown color as opposed to a dark brown (normal) color for oil - unless you've recently had an oil change - then it will be like honey. If you don't see any discoloration - I would then look around the the bottom of the area where the valve covers are located - the valve covers sit atop the heads and if you have a "blown" head gasket - you may see evidence of water/coolant seepage. You can also take the vehicle to a mechanic, who can do a simple test using air pressure to isolate a potential gasket issue.
As for the transmission problem - it could be any number of things - first and easiest thing to check, is your transmission fluid. Make sure that you check after the vehicle has been operating for a while and is on a level surface. You're checking for a couple of things here - proper fluid level - and the color/odor of the fluid itelf. Transmission fluid should have a purple/red hue to it, and be somewhat clear; not a dark, murky look. If you smell the fluid, and it has a "burned" odor to it - you should get a fluid change done, as well as filter.
I hope this helps and good luck!
Sep 25, 2009 | 1997 Jeep Cherokee Country
Patchy print
The printer has a built-in cleaning routine that you can access from the front panel menu, but it sounds to me like it may be more severe. I suspect you have a clogged print head. You may as well try the cleaning first, since that's free: Navigate through the menu to Support, Improve Print Quality, Eliminate Light Stripes. You may try this up to three times to see if it improves. If not, and if you're reasonably handy, you can probably replace the print head yourself. Contact DocJams.com for parts and directions, and tell him MaverickSolutions.biz referred you. I get all my Phaser parts from him - he's terrific and provides great support.
Jul 21, 2009 | Xerox Phaser 8200 Laser Printer
The paint on my TL has developed patches of what
Sorry but this is your clear breaking down from age and sunlight uv The clear is so brittle and thin it just scatches off
Jul 04, 2009 | 1999 Acura TL
My patch tool is working in reverse!
I just opened Photoshop, and tested this.
The patch tool works like this. You circle the portion of the image you want to use to cover the "white" area. Once you circled that area, you drag the selection to the "white" area.
Hope this helps.
Dec 02, 2008 | Adobe Computers & Internet
Miscellaneous Logo
48 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
