Question about Performance Teknique Icbm-9021 Pll Synthesizer Fm Modular
HOW TO INSTALL WHERE TO MOUNT
WHERE IS BEST PLACE TO MOUNT
How do I install a replacement door
If your talking about a sliding door. On a van. Best to remove the bolts from the tract mount, leave it in place. Bolt the door to it. if the bearing is bad in it. Still remove the door first. Slide the bracket out.
Dec 24, 2016 | Cars & Trucks
Can I mount carbon monoxide alarm on the ceiling?
I've read that the ceiling is the best place to put it. If you mount it on the wall it should be on open wall, not in a corner. Where ever the air can flow easy can be the best place.
Hope this helps.
Feb 26, 2015 | Home Security
Whats the best antenna and location on an f250 ford p/u ext cab superduty
Something like either a Wilson 1000 or 5000 magnetic mount on the roof--coil and whip unit detach as needed.
Apr 12, 2012 | Cobra 29 LTD CB Radio
Trying to R & R the serpentine belt on a 1999 Olds Delta 88. The belt is routed arond a motor mount. Do I have to jack the motor and disconnect it from the motor mount in order to remove and replace...
yes you do. place a floor jack under engine with a block of wood on top of jack to protect the engine, put just enough pressure on jack to steady engine. remove motor mount, then jack up engine a bit to take belt off. replace the belt then lower jack and attach the mount. on the mount only the outside bolts need to come off to raise engine. do not remove from engine side unless you are changing it or its bad, be carefull when raising engine, pick it up from a sturdy place, not the oil pan. have a good day !!
Jun 07, 2011 | Oldsmobile Delta 88 Cars & Trucks
How to change the alternator on my 2000 grand voagear
This is for a 3.3L motor
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
REMOVAL
  1. Release hood latch and open hood.
Removal/Installation of Battery Cables 81929864
  1. Disconnect battery negative cable.
  2. Remove windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  3. Remove accessory drive belt.
Generator Mounting Bracket 81929870
  1. Remove bolt holding top of generator mount bracket to engine air intake plenum.
  2. Remove bolts holding outside of generator mount bracket to generator mount plate.
  3. Remove bolt holding top of generator to mount bracket.
  4. Remove generator mount bracket from vehicle.
  5. Rotate generator toward rear dash panel.
Generator 81929868
  1. Disconnect the push-in field wire connector . from back of generator.
  2. Remove nut holding B+ wire terminal to back of generator.
  3. Separate B+ terminal from generator.
Generator Pivot Bolt 81929871
  1. Remove bolt holding bottom of generator to lower pivot bracket.
Generator 81929872
  1. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt.
  12. Install windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
Jan 02, 2011 | 2000 Plymouth Grand Voyager
How to change engine mount in 2004 Mitsubishi outlander
THAT REALLY DEPENDS ON WHICH ONE THE ALL HAVE A DIFFERANT R & R PROCEDURES ..( R&R REMOVE AND RE INSTALL)
Dec 25, 2010 | 2004 Mitsubishi Outlander
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Nov 04, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Insatalling a towbar on a wrangler
tow bar mounts directly to chasis or the front bumper steering wheel locked in place
Jun 08, 2008 | 1998 Jeep Wrangler
Performance Teknique Icbm-9021 Pll Synthesizer Fm Modular Logo
162 people viewed this question
Top Performance Teknique Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Performance Teknique Audio Player and Recorder Expert? Answer questions, earn points and help others
