Question about Hyundai 2007 Sonata
2007 Hyundai Sonata GSL CRUISE CONTROL ISNT WORKING
SOURCE: cruise control doesn't work
does cruise show up in led when you start engine
Posted on Sep 29, 2008
SOURCE: cruise control stopped working in my 2004 Hyundai Sonata
This works...the cruise is directly tied to the brake lights...when I replaced the brake and side light bulbs on my 2004 Santa Fe,,,the cruise started working with no other adjustments. It must complete a circuit or something.
Posted on Jan 05, 2009
  • 32 Answers
SOURCE: cruise control stop working can someone tell me how to fix myself
If all the brake lights are out it is likely your stop lamp switch is bad, it controls lights and cruse, and also supplies input to ecm/tcm. The old ones would just pop apart, you can put them back together but to replace the switch it is only 20-30 bucks. Try that.
Posted on May 27, 2009
ghost4548
  • 776 Answers
SOURCE: hyundai sonata 2002 remote
There is a special (proprietary) programming electronics 'black box' for the keyless entry system on all Hyundai vehicles for programming the remotes. This programming is stored in either the BCM (body control module) or the ETACS module (Electronic Time and Control System).
ghost4548
  • 776 Answers
SOURCE: key is stuck in ignition in 2007 hyundai sonata
The problem is in the tumbler(s) inside the assembly. Before you do anything, try penetrating oil to see if that works... otherwise, the entire assembly will need to be replaced.
Posted on Jun 28, 2009
Car wont turn over having trouble finding the fuel filter
Anonymous ,2002 Hyundai sonata gsl v-6 2.7 had some problems with a purge valve solenoid, especially after refueling hard staring, check the link below.
press the helpful button
Fuel Problem with the Hyundai Sonata
Feb 10, 2016 | Hyundai Cars & Trucks
After I got my tires rotated, I get an ESG light on my dashboard. The cruise control does not work either.
TPS SENSOR, Symptoms of TPS failure CEL, ESC OFF LIGHT ON=TOTAL ...
www.hyundai-forums.com/.../147913-tps-sensor-symptoms-tps-failure-c...
Sep 3, 2012 - 10 posts - ‎5 authors "CEL" comes on (Check Engine light) Code=P2135 IIRC ... My car is Sonata model 1994 automatic with 4 cylinder. .... Join Date: May 2010.
Sep 08, 2015 | Hyundai Cars & Trucks
206 SONATA CUSE CONTOL DOESNT WORK
You could possibly have a "brake lamp switch" faulty in your vehicle. There is a recall on these for certain model vehicles. Your vehicle may think your brakes are on, which isn't allowing the cruise control to activate.
Also the new Hyundai's are manufactured that if the Engine light is on, your cruise control won't work.
But I would try the Stop Lamp Switch first.
Hope this helps.
Oct 10, 2014 | 2006 Hyundai Sonata
2011 Hyundai Sonota Cruise Control: My new sonota's cruise control does not brake the vehicle when going down a hill. The car begins to increase its speed by over 20 km per hr and would exceed that amount...
I just bought a 2011 Sonata and am experiencing the same problem. Going downhill with cruise set at 55 mph; speed increased to 70 mph and was still accelerating (from the downhilll grade) when I finally pressed on the brake.
This is not normal. My Honda Accord never varied from the cruise setting by more than 3 or 4 mph ... going uphill or downhill.
Oct 12, 2010 | Hyundai Motor 2004 Sonata
Cruise control 2000 hyundai sonota gls
Hello. If the engine light or ABS is on then the cruse control will not work.
Dec 06, 2017 | 2000 Hyundai Sonata
Cruise not working in hyundai sonata 2000
Either the cruise switch you depress is at fault or the box withe the cables running from it to the throttle body is. It will need to be checked out if the fuse is good located in the fuse bos
Mar 27, 2010 | 2000 Hyundai Sonata
Brake light still don't work after changing switch assy-stop lamp
Not enough information in your description of the problem. You start with "brake light still don't work after.... "??? after WHAT? Then you write .. 'and cruise control for a sonata 2000 2.4... etc." I'll take WILD GUESS... you have a brake lamp switch which is broken/malfunctioning. Please remember to RATE my response.
May 28, 2009 | 2000 Hyundai Sonata
Cruise control stopped working in my 2004 Hyundai Sonata
Sep 11, 2008 | Hyundai Motor 2004 Sonata
Hyundai 2007 Sonata Logo
49 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Steven Mitchell
Steven Mitchell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
