Question about Refrigerators
Fridge working as normal but when compressor runs it makes noise like it can't decide what gear it is in and 1 of the 2 noises is more of a groaning sound (like it is going to quit) the alternating noises continue until compressor finishes cycle. Fridge 10+ years old and water line freezes frequently. Repair or replace?
  • Refrigerators Master
  • 5,323 Answers
DOES IT HAVE A CONDENSER FAN AT THE COMPRESSOR?
WHICH MAY BE IMPEDED OR GOING BAD?
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 07, 2015
  • 42 Answers
SOURCE: groaning noise on GE side by side refrigerator
Hello Michael,
Thanks for your question, I hope I can help some. My answer is long winded but full of good info.
The noise could be as the GE guy said refrigerant (gas) noise. If it is refrigerant noise it happens as the liquid refrigerant comes out of the tiny capillary tube and enters the evaporator (cooling) coil in the freezer. Along with the liquid coming through the capillary tube there often are gas pockets. The flow of the liquid and gas pockets into the evaporator coil cause strange sounds. If the noise you are hearing is this refrigerant noise, you should only hear the noise while the compressor is running and then only for a short time (1 to 2 minutes) after the compressor shuts off.
If the noise continues after that I do not think it is a refrigerant noise.
There are times when the compressor will not be running but the fan in the freezer will be running on this model. This is normal and working properly but if the noise is present when the freezer fan is running and the noise stops when the freezer fan stops, the likely cause will be the main board located in a square panel on the rear of the refrigerator above the compressor compartment. I know that sounds crazy but the main board can cause the freezer fan motor to make some really strange noises. Eventually the board will probably fail.
One other test would be for you to listen for the compressor to turn off, then if the noise is present after the compressor turns off, you would next unplug the refrigerator from the receptacle. If the noise continues with the refrigerator unplugged it must be refrigerant noise. If it stops, I am betting on a bad main board.
I tried to locate for you information on a material that Whirlpool and Frigidaire as well as some others use as a noise deaden-er that they wrap around where the capillary tube enters the evaporator. I was not successful in locating anything. I am sorry I could not find it.
supertechks
Please don't forget to rate me
Posted on Jan 25, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
huuum
  • 750 Answers
SOURCE: my whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
  • 5 Answers
SOURCE: fridge now groaning
My noise was the ice maker wire bail arm that turns on the ice maker.
I have no water line to the fridge, so the ice maker is not in use. The wife bumped the arm down that turns on the ice maker. I pushed it back up, turning it off and the intemittant groaning / buzzing stopped.
Too bad I replaced the perfectly good condenser capacitor first!
Posted on Mar 09, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Hotpoint Fridge Freezer makes a lough cracking / popping nose
think the door was left cracked open all day while we were at work, so it had to work to keep cold all day- and now it's making this horrible noise and not really cold as it should be. the noise is coming from the back, there are a few things that could be causing the problem. If the unit seems louder when the compressor starts, it's probably a normal sound. The compressor starts with a high pressure, but as the pressure balances, the noise should become normalized. The compressor is in a black case with no visible moving parts. It's located at the back of the refrigerator near the bottom and has wires and a bunch of tubes going to it. If it's humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components. If the compressor is making noise, there's probably no repairing it. You'll have to replace it. This is often a very costly job and needs to be done by someone with the necessary EPA certification to work on sealed systems.
Dec 19, 2013 | Hotpoint Refrigerators
I have a Fisher & Paykel Fridge Model E521T Serial # BSQ725303 The fridge is still working but it is making a groaning noise like the compressor is cutting in & out. Also the green & red...
Ah the evaporator fan is the noise.
Either the fan is hitting on built up ice or the bearings in the motor are worn.
If it is ice then you have a defrost problem and you will need a technician to help you there.
If it is the bearings you will need a new fan motor. Again a technician can help you
Mar 24, 2011 | Fisher and Paykel Refrigerators
Fridge Freezer makes 'groaning' noises
Sounds like it could be the icemaker . If the icemaker heater is bad , (replace icemaker ) , then it will groan while trying to dump the ice .You can try turning the icemaker off for a day and see if that stops the noise .
Aug 29, 2009 | Refrigerators
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore refrigerator is noisy
my kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Mar 05, 2008 | Refrigerators
Hello Michael,
supertechks
Jan 25, 2008 | Jenn-Air JFC2089HE French Door...
Whirlpool Refridgerator Noise
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Dec 26, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Fridge now groaning
Sep 14, 2007 | Amana ARB9059CS Bottom Freezer...
Groaning frig
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Apr 28, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
