Question about Sony Audio Players & Recorders
Sony HCD-HDZ485 flashing push power protector how do I fix it?
I have a Sony HD Receiver and DVD player that just started to flash the push power protector on the display and will not turn on
  • 3 Answers
SOURCE: Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Posted on Jul 17, 2008
SOURCE: Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Posted on Jan 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 02, 2009
ginko
  • 19396 Answers
SOURCE: flashes protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
  • 40 Answers
SOURCE: hello. my sony receiver is flashing protector mode
More than likly the built in amplifier is dead and its time to lay it to rest. Before you do that, make sure all your positive and negitives are correct and that none of the wires are touching one another.
Posted on Jul 25, 2009
Push power protector
if your pushing the power protector to on back its a resettable fuse an you have another insue inside shorting it out
Aug 03, 2014 | Sony Dream Home Theater System, DAV-DZ120...
When playing DVD, it's sometimes display 'PROTECT' and stop playing.
Check if you receive the error when playing any DVD in particular.
What happens when you take out the DVD and try playing it again? Does it play
This protector error denotes several possible problems. Heat, volume level and incorrect DVD settings may be the cause of the problem. The following steps will help you correct your problem and rid your amp of its "Protector" error.
  • Examine your volume setting to be certain that your volume knob is not at maximum. Having your volume cranked too high can cause the capacitors to overheat, shutting down the receiver.
  • Unplug your receiver and disconnect your speakers from the terminals on the back. This will allow you to determine if the error is internal. Plug your receiver back in and look for the same error message. If you continue to get the protector error without having your speakers connected, you may have an internal electrical problem. In this case, contact Sony about finding a repair center.
  • Reconnect your speakers one at a time. The order of connection doesn't matter. When reconnecting, be sure that you do not have your positive and negative speaker wires crossed in any way. After each connection, test your amp by running it with a source. Give each speaker a few minutes of power before connecting the next one. This will help you isolate which speaker terminal is causing the error. When the protector error returns, take note of which speaker connection caused it. Check this speaker wire for shorts or torn shielding.
  • Examine your ohm rating of your speakers if you have no shorts or wiring issues. Sony receivers are not compatible with speakers lower than 4 ohms. Connecting a lower ohm-rated speaker will cause an error.
  • Turn off the surround sound option if you have both your A and B position speakers in use.
  • Keep your receiver well ventilated. Overheating due to poor ventilation can also cause Protector errors.
  • Examine the sampling frequency of your connected DVD player. If the error only occurs when you watch a DVD, the sampling frequency of the DVD player may be set too high. Check the sampling rating in your receiver's manual and in the DVD player
Mar 22, 2011 | Sony DAV-S500 System
When powering on it flashes protector
This usually means that there is too much power flowing out of it.
Make sure that the speakers are rated within the ranges supported by this receiver.
To test this, you can unplug all speakers and try to power on.
If the unit displays this error with no speakers and no other pieces of equipment (dvd players, tvs, etc) then you would want to consult a pro to take a diagnosis.
If the speakers are the issue, then you should simply swap the speakers for the lower power requiring speakers it was designed to be used for.
Hope this helps!
Feb 23, 2011 | Sony STR-DE945 Receiver
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
My sony str-d1o15 says protector
I got this from Sony site, I am doing it to mine now, unplugged it first.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 20, 2008 | Sony STR-D1015
Flashing message on my reciever
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
Dec 15, 2008 | Sony STR-DE545 Receiver
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
