Question about Whirlpool Wfc7500vw Washer
Drum wobbles when empty - Whirlpool Wfc7500vw Washer
  • Whirlpool Master
  • 5,323 Answers
Can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Posted on Apr 02, 2015
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
Sounds like coming apart when on fast spin. Thought bearings might be bad but when empty can turn easily by hand like bearings ok. when empty drom can be turned easily and noticed tub can be bounced any...
When you turn it by hand and there is noticable wobble or play in the drum, it could only mean that the spider or support arms are broken. It is an expensive repair. Call the company and see if they will help you out in getting it fixed since the parts alone cost a few hundred dollars. Google "kenmore front load washer problems" to see the problems with these machines. Sorry.
Feb 08, 2011 | Kenmore 44042 Front Load Washer
My washer wobbles a lot. I tried to wash a comforter in it and after that it wobbles and the drum is very loose now what might be wrong
If really bad sounds like drum bearings worn to excess......assume you've adjusted the level on the front feet?
Dec 08, 2010 | Admiral AAV7000A
Loud banging noise looks like the drum is off set and it damaged the rubber in the front
If the inner wash drum is sagging when it is empty, it probally means that the support arms that hold the drum has failed. If you turn the drum by hand and if you hear any kind of banging noise or the drum wobbles more that a fraction of an inch, then the support or spider arms are broken.
You can't buy the spider arms seperately and must buy a drum and spider as one unit. The cost to repair would be in the hundereds. See the following link to judge for yourself if you want to fix it yourself or have it fixed. http://www.fixya.com/support/t4267953-spiderarm
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washing machine wobbles when spinning. Legs are level so is problem inside?
Check the suspending springs inside. These are attached to to the drum jacket. If the springs are OK check whether the drum is wobbling. Turn by hand and check. Check ball bearings last!!!
Mar 28, 2010 | Washing Machines
When activated the drum makes a low pitched squealing sound. drum seems to wobble
please replace felt around drum thank you for useing fixya RATE ME
May 16, 2009 | Dryers
Drum wobbles too much
sounds like you have got either a collapsed suspension leg or your bearings gone
Jul 21, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Wfc7500vw Washer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
