Question about Vehicle Parts & Accessories
Parking lights not working
One remote start was engaged parking light would blink once and then ren steady. Now the lights remain off until I manually turn on when I get in my vehicle.
    Genius:
  • 1,249 Answers
Sounds like they are working normally...
Posted on Apr 02, 2015
emo-of-death
  • 9 Answers
SOURCE: remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Posted on Jan 06, 2009
  • 34 Answers
SOURCE: Remote won't work and parking lights blink
the blue wire needs to go to -input then unit should work
Posted on Jan 09, 2009
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
  • 151 Answers
SOURCE: I have a viper 350 remote starter. When it was
If you have the install manual check to see if there is a setting to change the parking light circuit from intermitten to continious. If you can select it to provide a constant signal then you can procede to step 2. Locate which pin in the unit controls the parking light circiut and trace it bace to the head light switch check all connections between the unit and switch. If you need further wiring schematic for your vehicle bulldog security.com has info for your vehicle.
Posted on Dec 25, 2009
  • 103 Answers
SOURCE: Remote start will not work, it keeps giving error
is there a toggle that was installed inline? If the unit doesnt see a ground on the neutral afety switch wire, the remote starter will not crank.
Posted on Aug 13, 2010
I have a clarion rk20 keyless entry and remote start on my 2003 jeep grand cherokee it works fine but whenever i remote start it, its parking lights continue to flash as if the hazard lights were on?
After doing some poking around, I found that flashing parking lights are an indication that the remote start is being used. According to the information I found, the parking lights shouldn't keep on flashing after your 2003 Grand Cherokee has started. I am assuming that your parking lights, however, continue to flash even after the engine has started and you have put your Jeep into gear. Please let me know if that is the case as if it is then you likely have a short somewhere in the wiring that is telling your alarm system's brain that the remote circuit is still being used.
In order for something like this to happen, the major power line is usually pulled high when the remote is activated. When it is pulled high, the computer tells your car's parking lights to enter flash mode. What should happen next is that when the system has fired, the line should drop back to standard voltage and, at that point, the change in voltage should tell your parking lights to go back into standard mode.
What is happening instead is that the flasher light activation circuit remains high even after it is supposed to reset to normal.
The usual cause of this is a short somewhere on the input side of the alarm circuity. It is this side of the circuitry that pulls the parking lights into flash mode. It may be as simple as a short in the alarm system's switching wire harness (even something as simple as a loose crimp on a spade connector or a molex plug insert can cause it.
If you do not have easy access to the switch wiring, the wiring harness or loom, I would suggest taking it to a good alarm shop, telling them what is going on and having them trace the circuits until they find the troublemaker.
Nov 05, 2014 | Cars & Trucks
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
Feb 19, 2012 | 1992 Buick Century
I need the codes for mi jumbo universal remote on my tv sharp
  • 004
  • 009
  • 079
  • 095
  • 111
  • 112
  • 123
  • 124
  • 173
  • Those are all the codes from the manual for Sharp T.V.s
  1. So now turn the item on you want to control with the remote.
  2. Press the corresponding button.
  3. Hold "set" till the LED stays steady.
  4. Enter the 4 digit code.
  5. When entering the 4th number the LED should shut off.
  6. This means that your remote is set for that device.
  7. Press OK to store the code.
  • If the LED blinks 3 times and goes steady again the the code is not the one you want and you need to start an step 1 again.
  • You can also try the Code Search Function
  1. Turn on the device you wish to match with your remote.
  2. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red.
  3. Press the button on the remote for the item you want to program.
  4. The LED light should blink once and then remain a solid red.
  5. Press the On/Off button slowly until the device you want to program turns off.
  6. The LED light will blink once each time you depress the On/Off button.
  7. When the device you want to program turns off, press the ENTER button.
  8. The LED button will turn off and the code for that device will be stored in your remote.
Regards, Tony
Apr 28, 2011 | Innovage Jumbo Remote Control
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
2006 Chevrolet Uplander Parking Lights Stay On
My 2006 Uplander would not shut off the parking lights. I came here for a solution. I saw the answer here, actually the question, and I used the key fob to lock the vehicle. The lights went off. That was a temporary solve. Now, is this a "glitch" or a "feature"?
Sep 04, 2009 | 1996 Chrysler Town & Country
97 Subaru Outback ELECTRICAL-lights stay on-NOT park light switch
do you have a trailer hitch with a wiring convertor box when these malfunction you have some crazy problems,if not you may have a broken solder joint on the steering column switch i have seen this before
Jun 23, 2009 | 1997 Subaru Outback
Remote wont make truck start?
Jan 06, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
