Question about Garden
Model Wp_2402_swhb pressure machine. can i only put the engine gc160 or is there any other model of engine I can use for this machine? Thanks!
2 Suggested Answers
  • 68 Answers
SOURCE: For pressure washer Model WP-2402-SWHB,
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Posted on Feb 08, 2010
I need a throttle return spring for my Honda generator model gc160
I found it at this website. Very inexpensive. Dave Delano
http://www.ereplacementparts.com/spring-throttle-return-p-554603.html
Nov 28, 2016 | GC160 160cc Engine - HE GC160LA PHA
I have a honda GC160 prssure washer. I tfires up good, but when you squeze the trigger no waters comes out of the gun?
Hiand welcome to FixYa, I am Kelly.
GC160 is the engine number.... It does not tell me that pressure pump is on the unit.
There should be a large knob on the side of the pump head. That is the bypass / unloader valve. Removed that and clean the pump housing where the flat plunger mates to the bousing. Then disassemble the unloader vavle. Remove the lower part of it from the knob and clean off the corrosion and dirt from the plunger and spring. Clean everything brass.... Reassemble using what you could consider abnormal amounts of WHITE GREASE. Place a GOB of white grease into the pump housing be re-installing the unloader / bypass valve. Just remember when you hook up water for a funtional test, that your going to spray some off that extra white grease through the pump and wand nozzle.
This should get you going again. If not I need a model number for either the pump body or the whole pressure washer vs the Honda engine number of GC160.
Thanks for choosing FixYa,
Kelly
Aug 01, 2011 | Garden
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine running, no water will pass through the pump.
Dec 11, 2009 | Garden
Runs fine gc160 wont give me any pressure. i took the pump apart and cleaned it then put it all back together the pressure was intermediate but now nothing at all
if you give us a bit more information we may be able to assist!
is it a pressure washer you are trying to get running.
the number you give is the model number of the honda engine. 5.5 hp honda domestic use.
what does the pump look like. etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
The tubing from the gasoline is not connected
Devilbliss / Excell pressure washers in this model number range use a Honda GC160 engine. Information on this engine can be found here:
http://www.excellpressurewasher.com/documents/pdf/gc160.pdf
This web site also has information about the pump and related parts just look for your model number. I find that pressure washer manuals have very little information about the engine. Small engine / mower repair shops in your area will be happy to give you free information about the where the fuel line attaches. Your engine has a black plastic fuel pump with hoses going to tank and carb. This fuel pump is powered by engine crank/vacuum purssure so there is a third hose from the fuel pump connected to the engine block. Good luck on your repair and email if you have a question or if you have a different engine than mentioned above.
May 09, 2009 | Garden
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
