Question about Worldwide 1997 Honda Accord EX 2.7L Alternator - 90 Amps
I lost the panel that depicts the fuse. Is anyone famliar with the BRAKE fuse. I would like to check as my BRAKE light is on thank you LilaK
  • 3,519 Answers
Hi Lila:
If the brake light is on, it is getting power, so the fuse is OK.
I would suggest that you check the brake light switch, as it may be stuck in the on position. Brake light switches can be either on the master cylinder, or sometimes next to the brake pedal linkage under the dash. Chances are yours will be on the master cylinder. To check it, disconnect it. If the brake lights go off, the switch is defective and needs to be replaced.
Hope this helps.
Posted on Apr 02, 2015
Lost my tail light and running lights on 1984 Honda Magna 500
Check you have power from the switch to run the lights.
Jul 06, 2017 | Motorcycles
Main brake lights won't light
check your ground should have one for brake lights
Oct 01, 2009 | 1998 Ford Contour
2004 Grand Jeep Cherokee, Overland. Rear lights and brake lights not working. Drove last night with no lights at all in back - completely dark. Turn signals work. Checked fuses (I think I checked the...
After checking the fuses I would replace the fuse for the tail lights just to make sure it wasn't a fuse issue and if that doesn't do it I would check the bulbs on both sides to make sure that the bulbs are good.
Aug 16, 2009 | 1996 Chevrolet K1500
2001 Volkswagen Passet brake lights don't work
It should be printd into the fuse cover. If you can't see a fuse blown, then thats not your problem. Check the clearing at the top of the brake pedle to the brake acuator and if there is an overlarge gap it will not work the electrical circut.
Aug 02, 2009 | 2001 Volkswagen Passat
Not your typical brake light problem...
the bmw lights passes through a module called the check control module. it is responsible for giving a warning if the bulbs are busted. it must be the module
Jun 03, 2009 | 1996 BMW 318
Brake lights not working
Having the sa but haven't replaces the brake switch. The owner's manual for my 99 accord indicates the the fuse is located behind a panel that is viewable when you open the door on the driver's side. There is a panel that you remove (pull off) to expose the fuses. The brake light fuse is the third one from the top on the left. 7.5 A
May 22, 2009 | 1999 Honda Accord
Brake lights and crusie don't work
1ST THING TO CHECK IS THE STOP LAMP FUSE . FUSES LOCATED LH SIDE UNDER HOOD. THIS FUSE ALSO POWERS THE ACC. CIRCUT IN TRUCK. ALOT OF TIMES, LAP TOPS, DVD PLAYERS ETC. OVERLOAD CIRCUT & FUSE BLOWS.
Oct 25, 2008 | 2002 GMC Yukon Denali
1990 Mazda Miata, Tail lights, Interior lights not working! :\
I have a problem with my tail lights in my mazda. Brake lights working great but the light that supposed to be working during night time are not. By the way the front lights are working too! Also the light of the panel inside is not working. Can anyone please tell me how to fix it?
Thanks alot in advance!
Sep 06, 2008 | 1990 Mazda MX-5
1987 22R blinkers and gages not working and discharging
check fuses or could be condensation or bad ground common sense first check fuses under dash drivers side
Jul 13, 2008 | 1987 Toyota Pickup
Worldwide 1997 Honda Accord EX 2.7L Alternator - 90 Amps Logo
Top Worldwide Electrical Supplies Experts
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
